Autodesk 3Ds MAX 2021.2
Пол: М
На сайте c: 21.08.2013
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/35156605-CE91-4AF6-8207-56211CB30369/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_001_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/35156605-CE91-4AF6-8207-56211CB30369/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_002_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/35156605-CE91-4AF6-8207-56211CB30369/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_003_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/35156605-CE91-4AF6-8207-56211CB30369/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_004_004.sfx.exe
Что нового: https://help.autodesk.com/view/3DSMAX/2021/ENU/?guid=GUID-566A8DA5-C3EA-472F-B846-AB334616D6BD
Autodesk 3Ds MAX 2021.1
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_EFGJKPS_Win_64bit_001_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_EFGJKPS_Win_64bit_002_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_EFGJKPS_Win_64bit_003_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_EFGJKPS_Win_64bit_004_004.sfx.exe
3ds Max 2021.1 r1
https://dds.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_r1_EFGJKPS_Win_64bit_001_004.sfx.exe https://dds.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_r1_EFGJKPS_Win_64bit_002_004.sfx.exe https://dds.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_r1_EFGJKPS_Win_64bit_003_004.sfx.exe  https://dds.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_r1_EFGJKPS_Win_64bit_004_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/63E26FFF-3A8A-4339-BD61-CDB2350435C8/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_001_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/63E26FFF-3A8A-4339-BD61-CDB2350435C8/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_002_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/63E26FFF-3A8A-4339-BD61-CDB2350435C8/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_003_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/63E26FFF-3A8A-4339-BD61-CDB2350435C8/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_004_004.sfx.exe
Security Tools for Autodesk® 3ds Max® 2021-2015SP1
Help: http://download.autodesk.com/us/support/3ds_max_2021_help/3dsmaxhelp2021_enu.exe
Что нового в 2021.2:https://help.autodesk.com/view/3DSMAX/2021/ENU/?guid=GUID-263FADB9-DC7A-4B87-BACE-8D47280418EE
Пол: М
На сайте c: 30.06.2017
 нажимаю шифт
Нужно не нажимать, а зажимать! это я так , мало ли
Пол: М
На сайте c: 20.08.2007
да - зажимал, нажимал, отжимал, выжимал - результат один
https://dropmefiles.com/A287h
Пол: М
На сайте c: 20.11.2019
Подскажите, как разъединить элементы одного меша в отдельные объекты?
Пол: М
я где то скрипт такой видел на скриптспоте
Пол: М
На сайте c: 28.11.2007
Этот косяк, только если на модель наброшен Edith Poly. В Editable Poly всё корректно.
Пол: М
juj/ Я не подумал. Щас проверю Спасибо!
Да - эпический косяк автостолов... не первый и не последний.
Пол: М
Я ничего не накидываю, просто конвертирую в Editable Poly
Пол: М
На сайте c: 03.04.2010
Переведи в мэш. Explode с макс значением (180)
Пол: М
На сайте c: 02.10.2006
Цитата александр...:
Не выделяются нормально полигоны , когда они находятся внутри объекта .
Кто-то подскажет как. Не нашел. До 2021.2 по кругу все нижележащие выделялись. Где-то есть в настройках назад переключить? Как было.
Пол: М
На сайте c: 03.08.2009
Добрый день.
Очень прошу помощи. Есть ли в 3d max 2021 возможность отключить физичискую проработку материалов в превьюхе эдитороа с шариками? Система не слабая, а подзалипает на редакторе. Тяжело работать. Возможно кто нибудь знает, как сделать старый вид материалов на предпросмотре.
Пол: М
На сайте c: 08.12.2009
Цитата Ghonatan:
Добрый день.
И сохрани по дефолту
Пол: М
На сайте c: 11.07.2009
Нет не выделяются полигоны по кругу, настроек что то не нашел
Пол: М
попробуй с ctrl
Пол: М
На сайте c: 11.06.2017
Отправил в личку.
Пол: М
На сайте c: 26.02.2010
подскажите, в меню File/open Recent можно закреплять недавно открытые файлы ?
есть такие кнопочки ? в 2020 таких нет (  а в 2021 есть ?
Пол: М
На сайте c: 26.08.2010
В 2021 тоже нет. Бесит )
Пол: М
странно что убрали, может можно как-то скриптом сделать...
Пол: М
Неужели ни кто не столкнулся с проблемой выделения полигонов обратной стороны ?
Пол: М
На сайте c: 20.01.2017
Цитата Jähman':
Known issues and workarounds:
Issue: If a vertex, edge, or face point overlaps with another when working with edit poly/editable poly, only the closest point will be picked when you click on it. You will not be able to cycle through the overlapping points by clicking in the same spot, as you normally would. Workaround: Rotate the view and click on the desired point. MAXX-5890 smiley-lol.gif
Пол: М
нет это немного не то , именно не возможно кликом выделить полигон с обратной стороны , возможно только если выделять его окном и потом убирать выделение с ненужных полигонов , которые вместе с ним выделились
