Autodesk 3Ds MAX 2021.2
Пол: М
На сайте c: 21.08.2013
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/35156605-CE91-4AF6-8207-56211CB30369/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_001_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/35156605-CE91-4AF6-8207-56211CB30369/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_002_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/35156605-CE91-4AF6-8207-56211CB30369/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_003_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/35156605-CE91-4AF6-8207-56211CB30369/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_004_004.sfx.exe
Что нового: https://help.autodesk.com/view/3DSMAX/2021/ENU/?guid=GUID-566A8DA5-C3EA-472F-B846-AB334616D6BD
Autodesk 3Ds MAX 2021.1
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_EFGJKPS_Win_64bit_001_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_EFGJKPS_Win_64bit_002_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_EFGJKPS_Win_64bit_003_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_EFGJKPS_Win_64bit_004_004.sfx.exe
3ds Max 2021.1 r1
https://dds.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_r1_EFGJKPS_Win_64bit_001_004.sfx.exe https://dds.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_r1_EFGJKPS_Win_64bit_002_004.sfx.exe https://dds.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_r1_EFGJKPS_Win_64bit_003_004.sfx.exe  https://dds.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_r1_EFGJKPS_Win_64bit_004_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/63E26FFF-3A8A-4339-BD61-CDB2350435C8/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_001_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/63E26FFF-3A8A-4339-BD61-CDB2350435C8/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_002_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/63E26FFF-3A8A-4339-BD61-CDB2350435C8/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_003_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/63E26FFF-3A8A-4339-BD61-CDB2350435C8/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_004_004.sfx.exe
Security Tools for Autodesk® 3ds Max® 2021-2015SP1
Help: http://download.autodesk.com/us/support/3ds_max_2021_help/3dsmaxhelp2021_enu.exe
Что нового в 2021.2:https://help.autodesk.com/view/3DSMAX/2021/ENU/?guid=GUID-263FADB9-DC7A-4B87-BACE-8D47280418EE
Пол: М
На сайте c: 20.01.2017
если это не с ignore backfacing связано то это еще более жуткая жуть
• Improvements to selection when using backface culling, which make it easier to select what you need and avoid accidental selections (PU2)
ну либо они и тут набаговали
Пол: М
На сайте c: 31.03.2008
Цитата александр...:
именно не возможно кликом выделить полигон с обратной стороны
Именно бэкфейс, который не перекрыт во вьюпорте другим фейсом? Скриншот/видео было бы понятней.
Как и написал Jahman, в 21 теперь нельзя последовательными кликами выделять фейсы, которые перекрыты другими.
Пол: М
На сайте c: 11.07.2009
Цитата -NiK-:
еперь н
если нельзя то это пипец , я именно про это .  моделить вообще не удобно стало
Пол: М
На сайте c: 23.07.2016
Скачанный с официального сайта 2021 не смог вылечить, может кто шепнуть в лс ссылку на 2021.2 с таблетками, а то на персии  у меня нет аккаунта? Срочняк прям как надо smiley-sad.gif
Пол: М
Makasharip
Установите Network License Manager. Этот способ дает вечные лицензии на все продукты Autodesk.
Изучайте
Пол: М
Огромное всем спасибо, друзья, у меня вся личка переполнена. Даже плагины предложили. Не ожидал такого массового отклика, чуть не прослезился. smiley-cray.gif
Отличное комьюнити здесь на сайте, как ни крути.
Пол: М
На сайте c: 05.04.2007
Ребят проверьте пожалуйста  нужно поставить камеру желательно CoronaCam и через камеру походить по вьюпорту  , через 5-10 секунд крайняк 20 сек  макс должен зависнуть .... тоже самое и с обычной камерой происходит уже боюсь через камеру ходить ...
Пол: М
На сайте c: 26.07.2008
зачем ходить через камеру?
Пол: М
На сайте c: 30.11.2016
Раньше в максе, чтобы выделить полигон, который находится как бы перекрыт другими полигонами, то нужно было просто жать лкм на одном и тои же месте и он по очереди выделял все полигоны на которые попадает указатель. В 2021.2 что-то это пропало, они изменили это или как теперь все реализовано?
Пол: М
Issue: If a vertex, edge, or face point overlaps with another when working with edit poly/editable poly, only the closest point will be picked when you click on it. You will not be able to cycle through the overlapping points by clicking in the same spot, as you normally would.
Workaround: Rotate the view and click on the desired point. MAXX-58907
smiley-biggrin.gif вот вам и решение по автодесковски.
Пол: М
Спасибо, ну хотя бы они знают об этом баге, значит починят
Пол: М
На сайте c: 28.09.2006
Судя по их предложенному решению проблемы, это не баг, а фича
Заметил ещё, что поломали отображение во вьюпорте карты Tiles при использовании галочки Mirror.
Теперь при включении Mirror отображение на объекте ограничивается только размерами маппинга по той оси, где включен Mirror. А если ещё и Tiling для миррор менять, то ещё больше сжимается (третий скрин).
Победить чота не смог пока.
Пол: М
На сайте c: 08.02.2012
Друзья, такая проблема, если объект двигать не за пайвот и просто переключая оси F5 - F8, почему то не все оси включаются. Т.е. если надо объект вручную подвинуть в приближенном состоянии не за пайвот, потому что его не видно,  то это не получается, не переключаются оси. Есть ли у вас такая проблема?
Пол: М
Пол: М
На сайте c: 23.02.2017
Поделись теперь со мной. У меня та же ситуация.
Пол: М
На сайте c: 10.02.2010
Установил 21.2 версию. Может зависнуть на чем угодно - копирование, выдавливание ребер, сохранение, экспорт... Глючит по полной. Для серьезной работы мало пригоден.
Пол: М
На сайте c: 17.03.2020
триальная версия его же, не лагает и не глючит :)
Пол: М
Делаю уже второй проект в 2021.2 Вылетал один раз за все это время
Пол: М
На сайте c: 17.03.2017
Пол: Ж
На сайте c: 15.06.2016
Всем добрый вечер, есть вопрос. Установили мне Max 2021, теперь при каждом сохранении сцены, когда я наживаю SAVE, сохраняет у меня как SAVE AS... то есть приходится каждый раз путь указывать. Это можно как-то исправить? И если да, то как, подскажите, пожалуйста!
