Autodesk 3Ds MAX 2021.3
Пол: М
На сайте c: 21.08.2013
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/35156605-CE91-4AF6-8207-56211CB30369/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_001_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/35156605-CE91-4AF6-8207-56211CB30369/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_002_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/35156605-CE91-4AF6-8207-56211CB30369/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_003_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/35156605-CE91-4AF6-8207-56211CB30369/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_004_004.sfx.exe
Что нового: https://help.autodesk.com/view/3DSMAX/2021/ENU/?guid=GUID-566A8DA5-C3EA-472F-B846-AB334616D6BD
Autodesk 3Ds MAX 2021.1
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_EFGJKPS_Win_64bit_001_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_EFGJKPS_Win_64bit_002_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_EFGJKPS_Win_64bit_003_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_EFGJKPS_Win_64bit_004_004.sfx.exe
3ds Max 2021.1 r1
https://dds.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_r1_EFGJKPS_Win_64bit_001_004.sfx.exe https://dds.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_r1_EFGJKPS_Win_64bit_002_004.sfx.exe https://dds.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_r1_EFGJKPS_Win_64bit_003_004.sfx.exe  https://dds.autodesk.com/NetSWDLD/2021/3DSMAX/69B5E9EE-26F7-49BA-9F6C-AFF2D8D1C443/SFX/Autodesk_3ds_Max_2021_1_r1_EFGJKPS_Win_64bit_004_004.sfx.exe
Autodesk 3Ds MAX 2021.2
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/63E26FFF-3A8A-4339-BD61-CDB2350435C8/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_001_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/63E26FFF-3A8A-4339-BD61-CDB2350435C8/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_002_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/63E26FFF-3A8A-4339-BD61-CDB2350435C8/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_003_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/63E26FFF-3A8A-4339-BD61-CDB2350435C8/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_004_004.sfx.exe
Security Tools for Autodesk® 3ds Max® 2021-2015SP1
Help: http://download.autodesk.com/us/support/3ds_max_2021_help/3dsmaxhelp2021_enu.exe
Что нового в 2021.2: https://help.autodesk.com/view/3DSMAX/2021/ENU/?guid=GUID-263FADB9-DC7A-4B87-BACE-8D47280418EE
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/84D3A5E6-54DF-38B5-B26F-8E542404F383/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_001_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/84D3A5E6-54DF-38B5-B26F-8E542404F383/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_002_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/84D3A5E6-54DF-38B5-B26F-8E542404F383/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_003_004.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2021/3DSMAX/84D3A5E6-54DF-38B5-B26F-8E542404F383/SFX/Autodesk_3ds_Max_2021_EFGJKPS_Win_64bit_004_004.sfx.exe
Autodesk Retopology Tools v1.0.0 for 3ds Max 2021
http://up.autodesk.com/2021/3DSMAX/76002408-59F6-4482-9A29-A9374F06173A/Retopology3dsMax2021-1.0.0-198.msi
Help:http://help.autodesk.com/view/3DSMAX/2021/ENU/?guid=GUID-A6332DC6-6B4B-49EA-9DB9-253410EDBD06
Пол: М
На сайте c: 11.06.2017
Цитата Стрелец:
а что это за приложение и где его взять?
А взять его можно здесьhttps://www.autodesk.com/desktop-app
Пол: М
На сайте c: 14.03.2007
Не скромный вопрос...А народная версия макса обновляется? )))
Пол: М
На сайте c: 23.07.2016
У меня всё обновилось со второго до третьего апдейта и Retopology Tools зашёл. Но я вручную всё скачивал и ставил, без всяких менеджеров )
Пол: М
На сайте c: 22.03.2007
Цитата egoroshe:
Кому актуально не забывайте что с этим обновлением устанавливается AGS. Будьте бдительны.
А что это?
Пол: М
На сайте c: 31.03.2011
M_E_T_I_S Autodesk Genuine Service
Пол: М
На сайте c: 30.06.2017
Привет Всем. Установил обнову 2021.3 и с ним же установил V rey 5.00.05, не подгружается настройки рендера, вылетает Макс, чистая сцена. Может кто сталкивался с такой проблемой? Попробовал все сделать заново, поставил все настройки под себя какие были в V rey ,сохранил, открываю чистую сцену , так же вылетает с подгрузкой настроек. ENU удалял , на вирусы проверял.Но самое интересное, когда загружаю старую сцену какую нибудь , то настройки подгружаются!!
Пол: М
На сайте c: 10.11.2009
"error 2503. Called RunScript when not marked in progress"
выдает такую ошибку при установке Retopology3dsMax2021
есть кто решил проблему?
Пол: М
На сайте c: 07.02.2010
Кто подскажет как избежать установки AGS? Раньше можно было поправить Setup.ini, а сейчас такой возможности нет, не хочется опять этот сервис изводить (кое-как от него избавился)
Пол: М
Я скачал по ссылке, вручную устанавливал... AGS не ставился, все нормально работает...
Пол: М
Это которые четыре EXEшника по ссылкам в шапке? Это разве не дист с МАХом в комплекте?
Пол: М
AGS устанавливается вместе с последним обновлением 2021.3. Что бы удалить AGS используйте RevoUninstaller или тому подобные утилиты, которые позволяют полностью "выкорчевывать" не удаляемые приложения вместе с их подследами.
M_E_T_I_S
Это ссылки на дистрибутив 3DsMAX 2021.3 с серверов Autodesk.
Пол: М
А саму обнову отдельно где брать? Или только через десктоп ап?
Пол: М
На сайте c: 26.07.2010
http://3dstudiomax.ru/index.php/blog/3d-grafika/98-install
Пол: М
На сайте c: 26.06.2012
Странно что, люди вообще заморачиваются с его удалением, тем более через сторонние утилиты. Я просто сразу убрал его из автозагрузки через стандартный диспетчер задач и больше он меня не беспокоил ни разу.smiley-unknw.gif
Не понимаю я этих танцев с реестром. Слишком сложно
Пол: М
На сайте c: 15.06.2020
мур_:
хамство.
ну может на персию привезут полный набор Max 2021 со всеми допами.
Пол: М
На сайте c: 25.01.2013
Здравствуйте, столкнулся с проблемой
Через Backburner 2019, 3D max 2021.3 - не хочет сохранять рендеры если есть русские символы.. хотя 2020 без проблем это делал... скрин лога прилагаю...
Может можно что-то подкрутить чтобы и 2021 макс смог сохранять нормально?
Пол: М
sh4d3rx
Чем лечили макс?
Пол: М
мур_:
хамство.
кто подскажет что не так с этим AGS, что это такое и почему его надо боятся?
Пол: М
Цитата Bestviz:
sh4d3rx
Чем лечили макс?
хфорс вроде
Но и на рабочем компе с лицензией всё тоже самое.. 2020 проблемы нет.. 2021 не хочет...
Причем напрямую из 3д Макса всё нормально сохраняется с русскими названиями.. а через Бэкбернер нет...
Пол: М
На сайте c: 06.08.2013
Autodesk Genuine Service  проверяет подлинность софта автостолового.
