Forest Pack 8.0.8
-New Effect function: 'fpTrimEdgeSpline(spline)'
* Applies Edge checking (similar to Area->Edge mode) of current item with the specified spline.
* It works with any distribution mode, incluing Custom Edit.
* It may be slow with large distributions, use with caution. Also for performance reasons, it works at render time only.
- Added support of ForestSet for Object Areas.
- Added 'Disable Set Content' to ForestSet. When enabled, Set content is ignored, working as an empty object.
- Fixed crash setting Object Area->Top Limit to zero.
- Fixed rare crash of multihread process computing exclude areas from other Forest objects.
- Fixed: Fake Shadows doesn't work in V-Ray.
- Fixed: Effect Name is not updated when loading from Library.
Forest Pack 8.0.9
- Fixed crash in V-Ray when Forest object has not items to render. (bug introduced in FP 8.0.8 ).
- Added 'mode' parameter to 'fpTrimEdgeSpline(spline, mode)' Effect function.
* When mode is 0, items outside of the spline are trimmed (as Include areas).
* When mode is 1, items inside of the spline are trimmed (as Exclude areas).
Forest Pack 8.1.0
- Fixed shadow of trimmed elements in Edge Mode, when using a Surface as area, and rendering with V-Ray 6.10.02.
- Improved viewport behaviour when editing items on Custom Edit and rendering with V-Ray IPR.
- Fixed crash using animation modes and Corona Interactive Render.
* Due to some limitations, animation modes with IR is available only in Corona 10 and above.
- Fixed: camera clipping is not updated on viewport when camera is deleted.
- Library import options are enabled only for libraries, not for folders.
У кого активные лицензии, можно устанавливать. У кого просрочена, можно продлить.
