interior | iminite1
Пол: М
На сайте c: 30.11.2020
Пол: М
На сайте c: 02.07.2014
Второй ракурс обязывает вас сделать пол более качественно. Всё, что близко должно быть максимально проработано.
Пол: М
Спасибо) здесь только одна ошибка?
Пол: М
На сайте c: 11.03.2021
I think you are in a hurry to design this .I will tell you some of the problems, I hope it will help you.
1- The furniture you have chosen for the space is not suitable, Use L-shaped furniture.
2- The bedroom door should not open towards the reception .
3- The paintings you put in the work have made the work very slutty. Finally, use one or two paintings.
4- In my opinion, the scale and size of furniture and other objects are not standard (they look very big).
5- Be sure to include space for the hanger you put in the reception. You have put a lot of paintings in the bedroom, be sure to fix it.
6- Be sure to use hidden lights to achieve better rendering.
See more examples of interior design.
Пол: М
thank you) I'm glad of you
