Цитата xpp_nd_ruphus:
что там нового?
Да есть маленько нового...
Corona Renderer 4.0 db от 03.01.2019
Daily Builds Changelog:
New & Improved:
- Preserving materials from overriding now works also for multi/sub materials.
- Added PhoenixFDOceanTex and PhoenixFDGridTex to the list of maps compatible with Corona
- CoronaBitmap will now automatically open file dialog when it is plugged into any bitmap slot in render settings
- TextShader no longer glows in GI and it is also independent on the colormapping (used at the start of the rendering)
- The new light solver is now on by default
- Improved autosave:
- Limitation of the number of kept files now works also when render stamps are used in autosave file name.
- The file counter is resumed from its last value even after restarting Corona.
- In case of final render autosave the file name suffix is now "end_<counter>" instead of "end<counter>".
- Added checkbox enabling/disabling denoised image blending to VFB. It is enabled by default (if denoising is turned on).
- “Export” and “Export+Render” buttons in render settings now remember the last used export path
- LightSelect element can be now set to contain all the unassigned light sources
- Corona color picker now supports alpha value (where applicable)
Fixed:
- Corona now warns that Color Correct map is not supported in standalone.
- Falloff is no longer swapping submaterials in standalone.
- Fixed incorrect shading result of screen-mapped OSL maps
- Fixed VFB spinners not behaving correctly when dragging the mouse across the top/bottom of the monitor.
- Fixed occasional flickering of CoronaVolumeGrid when using velocity-based motion mblur
- More than one light mix element can be displayed in vfb (all light mix elements use the same light mix settings)
- Fixed bug, where volumetric shaders gave wrong result on the first render, but worked on the second render
- Fixed different result of region render saved to file, compared to VFB content
- Fixed 3ds Max Hair and Fur modifier not rendered with "render selected"
- Fixed DR issue where some assets were not updated after they have been modified
- Fixed blurring & sharpening producing different result in VFB and in saved images
- If the motion blur is disabled, IR is no longer restarted when shutter speed of CoronaCamera changes
- If the depth of field is disabled, IR is no longer restarted when F-stop of CoronaCamera changes
