Gnomonology - Introduction To 3D Studio Max - 1.25 Gb
На сайте c 09.10.2006
Kiev Ukraine
3d Studio MAX is an industry leading application in design visualization, game development and visual effects.
3ds Max is powerful and flexible enough for professionals, but intuitive enough for the beginner.
Whether new to 3ds Max or new to 3D, the more than five and a half hours of lecture provide ample discussion of the tools needed to create visually rich imagery and animations. User interface foundations are presented, focusing on 3ds Max's ease and simplicity. Learn core concepts as well as efficient, professional modeling, animation, texturing, and lighting techniques.
Chapter One: Getting Started
User Interface Overview, Object Creation, Parametric Primitives, Viewport Navigation, Command Panel, Modifiers, The Stack,
Coordinate Systems, Gizmos, Modifier Instancing/Sharing, Keyframe Animation, Path Animation, Object Properties, Show and Hide.
Chapter Two: Modeling Fundamentals
Compound Objects, Booleans, Autogrid, Shapes, Text, Lathe, Scatter, Modeling with Primitives, Grouping, Grid and Units,
Real World Units, Object Pivots, Object Instancing, Mirroring, Selection Centers, Array Tool, NURBS, Polygons, Splines,
and Subdivision Surfaces.
Chapter Three: Modeling Techniques
Sub-Objects, Preview Selection, Soft Selection, Edit Poly, Extrude, Topological Dependencies, Radial Symmetry, 3D Snaps,
Relative vs. Absolute Snap, Angle Snap, Weld, Bevel, Working Pivot, Quickslice, Cut, Slice Tool, Chamfer, Normals,
Subdivision Surface Modeling, FFD (Free Form Deformer), Spacing Tool, Import/Merge, Linking.
Chapter Four: Texturing
UVs/Mapping coordinates, UV Visualization, Material Editor, Standard Shading Models, Specularity, Bitmap Texture,
Bump Mapping, Show Map in Viewport, UVW Mapping, Map Instancing, Material Preview, Material Libraries, Naming Convention,
Rename Tool, Multi/Sub-Object, Reflection Maps, Background Color, Skylight, Neutral Lighting.
Chapter Five: Lighting
Light Types (Omni, Spot, Directional), Target vs. Free, Decay, Attenuation, Shadow Maps (Resolution, Sample Range, Bias),
Raytraced Shadows, Area Shadows, Viewport Lighting and Shadows, Lens Effects, Viewport Layout, Asset Browser, Render Settings,
Antialiasing, ActiveShade, Environment Map.
Download from Rapidshare
http://rapidshare.com/files/95131376/GIT3DM.part01.rar
http://rapidshare.com/files/95135132/GIT3DM.part02.rar
http://rapidshare.com/files/95138669/GIT3DM.part03.rar
http://rapidshare.com/files/95142467/GIT3DM.part04.rar
http://rapidshare.com/files/95146670/GIT3DM.part05.rar
http://rapidshare.com/files/95150430/GIT3DM.part06.rar
http://rapidshare.com/files/95154683/GIT3DM.part07.rar
http://rapidshare.com/files/95159188/GIT3DM.part08.rar
http://rapidshare.com/files/95164425/GIT3DM.part09.rar
http://rapidshare.com/files/95168402/GIT3DM.part10.rar
http://rapidshare.com/files/95172353/GIT3DM.part11.rar
http://rapidshare.com/files/95176481/GIT3DM.part12.rar
http://rapidshare.com/files/95127776/GIT3DM.part13.rar
Download from FileFactory
http://www.filefactory.com/file/7d96dd
http://www.filefactory.com/file/cb8612
http://www.filefactory.com/file/2e097a
http://www.filefactory.com/file/89f13d
http://www.filefactory.com/file/365271
http://www.filefactory.com/file/d515de
http://www.filefactory.com/file/69cadc
http://www.filefactory.com/file/01831c
http://www.filefactory.com/file/41a8c2
http://www.filefactory.com/file/9c3410
http://www.filefactory.com/file/ab57a0
http://www.filefactory.com/file/cffcb2
http://www.filefactory.com/file/c220b2
For more info: http://anonym.to/?https  ://gnomonology.com/group/24
при скачивании - подчеркивание перед ссылкой убираем[/url]
На сайте c 24.07.2007
Arlond jeto vse vidiki???
Kiev Ukraine
да. это видео трейнер
