У меня процессор Xeon X79 E5-2690 v2 на топовой материнской плате своего времени и видеокарта RTX 4090. Эта информация для тех, кто столкнулся со странными подтормаживаниями в Windows 11 25H2, когда интерфейс дёргается при скроллинге. Мне помог разработчик Octane Render — вот его ответ. Но есть нюанс: в английской версии Windows, как я понял, этот пункт не скрыт. После отключения через командную строку — 3ds Max и AutoCAD ожили.
(The UI lag on a clean installation of Windows 11 25H2 with a Xeon E5-2690 v2 is a behavior that’s been reported by users with similar architectures running Windows 11. It generally comes down to two main causes.The first is VBS (Virtualization-Based Security), which is enabled by default. Windows 11 25H2 turns it on automatically, but the Xeon E5-2690 v2, being based on Ivy Bridge, doesn’t support MBEC (Mode-Based Execution Control), which is only available starting with 7th-gen Intel CPUs. Without MBEC, the virtualization layer has a much heavier impact on system responsiveness. You can try the following: open Settings, go to Privacy & Security > Windows Security, then click “Open Windows Security.” From there, go to Device Security, click on “Core isolation details,” and turn off “Memory integrity.” Then restart your PC. To verify that it’s actually disabled, press Win + R, type msinfo32, and hit Enter. In the window that opens, look for “Virtualization-based security”, it should say “Not enabled.” The second cause is the Power Plan being set to Balanced. On X79 platforms, this plan doesn’t handle CPU frequency scaling well when idle, which can cause visible micro-lag when moving windows or navigating the interface. Try switching the power plan to High Performance. After these two changes, the UI should feel responsive again. Also, make sure to install NVIDIA drivers directly from the NVIDIA website, rather than using the ones provided through Windows Update.RegardsParide)
Перевод Задержки интерфейса (UI lag) на чистой установке Windows 11 25H2 с процессором Xeon E5-2690 v2 — это поведение, о котором сообщали пользователи с похожими архитектурами при использовании Windows 11. Обычно причина сводится к двум основным факторам. Первая причина — это VBS (Virtualization-Based Security, виртуализация на основе безопасности), которая включена по умолчанию. В Windows 11 25H2 она автоматически активируется, но процессор Xeon E5-2690 v2, основанный на архитектуре Ivy Bridge, не поддерживает технологию MBEC (Mode-Based Execution Control), которая появилась только начиная с процессоров Intel 7-го поколения. Без поддержки MBEC уровень виртуализации создает значительно большую нагрузку, что негативно влияет на отзывчивость системы. Ты можешь попробовать сделать следующее: Открой Параметры (Settings) Перейди в Privacy & Security (Конфиденциальность и безопасность) Открой Windows Security (Безопасность Windows) Нажми Open Windows Security (Открыть безопасность Windows) Перейди в раздел Device Security (Безопасность устройства) Нажми Core isolation details (Изоляция ядра) Отключи Memory integrity (Целостность памяти) Перезагрузи компьютер Чтобы проверить, действительно ли функция отключена: Нажми Win + R Введи msinfo32 и нажми Enter В открывшемся окне найди строку Virtualization-based security — там должно быть указано “Not enabled” (Не включено) Вторая причина — это режим питания (Power Plan), установленный на “Balanced” (Сбалансированный). На платформах X79 этот режим плохо управляет частотой процессора в состоянии простоя. Из-за этого возникают заметные микрофризы при перемещении окон или работе с интерфейсом. Решение: Переключи план питания на High Performance (Высокая производительность) После этих двух изменений интерфейс должен снова стать плавным и отзывчивым. Также убедись, что ты устанавливаешь драйверы NVIDIA напрямую с официального сайта NVIDIA, а не используешь те, которые ставит Windows Update.
В виндовс стран СНГ в этом разделе ядра только два параметра, их трогать ненадо 1) защита локальной системы безопасности
2)список заблокированных уязвимостей драйверов Их не трогаем!
👌И тут как раз подвох Windows 11 СНГ версии — вообще нет пункта “Целостность памяти”.💥 Что это значит👉 Это НЕ нормально в обычной ситуации👉 Это значит, что:VBS (виртуализация) у тебя включён, но управление скрытоТакое часто бывает на:старых CPU (как твой Xeon v2)новых билдах Windows 11⚠️ Итог по твоему скринуТы в правильном месте ✔️Но Memory Integrity скрыт системой ❌Значит отключать надо в обход GUI🔧 Делаем правильно (рабочий способ)Отключаем VBS через системуНажми Win + R → вставь:bcdedit /set hypervisorlaunchtype off👉 ВАЖНО: запускать через cmd от администратора
ну и питание на максмальное переключите, вот два пунктап которые вам вернут быстродействие в прогах автостопа
оператвку видел ценник? уже под 2 касика баксов П.С. мне не нужен ни новый интел ни райзен так как рендерю на октане . он уделает с норм видюхой любой из перечисленных вирей или корону., Так -как работаю чаще с анимацией.
наоборот сейчас выбора у людей нет, кто только начинает или закончил вышку, Реально собрать комп только под х79 с 20 ядрами и 64 гигами оперативы ддр3, а можно и 40 ядрами чего хватит на все, даже зионы на х79 их хватает на все задачи.
Вероятно это с нами на долгие годы, того даже такой полезный пост оч пригодиться людям, Я вот пару дней думал, что у меня чет не то с дровами , винда прям свежая лицензия скачана вот позавчера с оф сайта. И если бы не разраб OTOY дальше бы переставлял систему не понимая че за тупняки
удивительно как люди на старых компах хвалят их, для всего хватает и для всех задач прям ))
Твой ксеон, проц 12ти летней давности и тупит в максе, нафига его советовать новичкам
нафига вообще вин11 ставить, тем более на старый конфиг? ну вот нарвались на проблему, это все равно не убедило поставить старую винду будете новые проблемы искать?
а про то что видяха уделает это сомнтительно, топовая видяах стоит как весь комп, что с оперативой стало это понятно же что временно, а вот цены на видяхи уже устаканились под 300к и это не нормально. и потом что вы там в 24гб сделаете? даже жк не сможете сделать. и вас не смущает что вся система во время рендера на видяхе лагает? а на цпу все плавно, хоть сиди играй во время рендера. и вообще на зеоне в максе работа сама по себе не плавная, ведь однопоток слабый а там весь интерфейс на нем завязан и большинство модификаторов в однопотоке работают.
хеон хеоном у мен видюха обладает 16 тысячами ядер мне этого хватает, думаю ненадо пояснять, что ваши 12 ядерники современные медленеее чем 4090? или 5090. Этим одним действием я вернул нормальную работу софта, и все работает абсолюьтно так -же как у вас.
П,С, пока вы там один кадр рендерите короной 10-15 минут, что очень долго, в CG -VFX если кадр больше 8 минут это убыточно, я у себя не юзая сервера могу анимацию рендернуть физикой в 4к на пазтрейсе, где кадр будет считаться до 2х минут, а чаще до минуты, две это если сцена весит под 100 лямов.
Вообще непонимаю, что докопались, таких случаев у людей полно, многие сидят на двухдаже зионах и все юдей устраивает. Я же работаю только с ГПУ лет 17
Украина, Одесса
Сорян за оффтоп, вижу автор темы уже бухтит :
Со стороны это и вправду выглядит странно, для меня. Рендрить анимации, считать минуты затраченные на рендер, 17 лет работать с GPU рендерами но при этом бухтеть на стоимость оперативки. Да, она конечно подорожала раза в четыре+. Да, конечно GPU рендеры кратно быстрее рендрят чем CPU. Я прост не пойму, причем тут все эти минуты на кадр. Почему я рендря в Короне часами панорамы статичные могу себе позволить хоть раз в месяц брать по 128GB DRR5 приличной оперативки, а у автора темы это вызывает какие то проблемы. Я бы подумал вот над этим, может проблема не в скорости рендера и не чем вы там рендрите, а в том сколько вам платят за работу 😉 Конечно я всех нюансов не знаю, может там расходы на содержание яхты, большая семья, дорогое хобби, тогда - ок, завалил свою хлеборезку )))
По теме :
Конечно же у старых архитектур процессоров целый пласт патчей безопасности накопился, которые грузом душат процессоры. Те же Meltdown, Spectre, это из тех что на слуху были. Процы тех лет душили и микрокодом и заплатками на Винду. Разумеется отключение изоляции ядра, гипервизора, изоляция таблиц памяти/буферов. Вся вот эта телега с защитой предсказателя ветвлений. Да, если вы готовы оставлять систему полностью беззащитной, можно отыграть кусок производительности отключив все это. И да, в отличии от Win10, в 11-ой часть этих заплаток стала более плотно интегрированной в систему, и насколько я знаю, отключение изоляции памяти может сломать DEP (а может и не сломать), соответственно совместимость тоже может похериться с (некоторым) софтом. Так что тут нужно понимать ещё что отключать, зачем и какие последствия (могут) быть, я не только про гипервизор. На Win10 с этим значительно меньше проблем. Специально почеркнул, что бы не было такого что кто-то вопить начнет что у него все кайф на Win11 с отключением всего этого дела и ноль проблем. Верю, может повезти.
В любом случае, если бы я сидел с старым Зионом, я бы оставался на Win10, отключал бы все это. Пусть даже с риском что хацкеры украдут все порно с моего ПК.
Вообще чисто на уровне архитектуры процессора, практически все эти косяки закрыли примерно во времена Ice Lake/Commet Lake. Так что все это в общем то актуально и для более свежих процессоров, наверное вплоть до ~2019 года. То есть условно у Интел (Xeon v4 / Xeon Platinum / 8700K / 9900K / 6950X / 7980XE / 9980XE) - все более менее страдают от этой же темы. Прост на низкочастотных Зионах с Mesh-Шиной и тугой архитектурой эти проблемы более ярко выраженные.
я тоже отключал заплатки для мелтадавн и тд. они же все работают только при физическом доступе к пк, либо запуском пользователем сам вирус, что сомнительно, если ты продвинутый юзер и при наличии антивирусника, который скаринует файлы до запуска. большинство дырок фиксят для корпоративного сектора, а не для домашнего пк к которому нет доступа и стоят продвинутые стороние защиты. хотя автор конечно может сидит на голой вин11 и ставит все обновы, которые ломаются каждый месяц, я не знаю)
ну авх2 да, но я вирей не юзаю, октан рендер прекрасно работает, ему авх2 не нужон У вирей РТ версия всратая, ничего толком не умеет, выглядит как не физический движок октан директ лайт, я же на гпу спокойно могу юзать фотон трейсинг и паз трейсинг с каустикй итд.
