Maxwell Render 1.6.1 Final 32/64bit
На сайте c 09.10.2006
Kiev Ukraine
Maxwell Render™ is a physically correct, unbiased rendering engine. By calculating complex mathematics, Maxwell Render is capable of simulating light exactly as in the real world. Unbiased means Maxwell Render™ does not use tricks to imitate real world behavior like other renderers – everything is reproduced as it is through governing physical equations..... Maxwell Render™ connects via plugins to the major 3D design and CAD applications like 3ds Max™, Viz™, Maya™, LightWave™, Rhinoceros™, SolidWorks™, Archicad™, CINEMA 4D™, form·Z™, and SketchUp™.
Maxwell Displacement
Displacement is a powerful texture-driven tool that can help users to create real geometric detail on objects on-the-fly while rendering. As opposed to many other displacement solutions currently available in the industry, Maxwell Render offers you its very own, unique displacement technology which is capable of simulating any detail without extra memory consumption.
Many of the other displacement methods presently offered, pre-tesselate the given geometry and displace the vertices of this new cluster, which wastes a lot of memory resources before and during the render. Maxwell Displacement does not use triangle tesselation methods and does not prepare subdivided/tesselated geometry before rendering. Even when rendering, this technology has nothing to do with additionally created triangles.
Maxwell’s powerful infinite surfacing technology is capable of rendering very fine displacements even beyond texture resolution. With its seamless precision control, users can easily customize surface accuracy/ability and optimize the performance depending on your needs. In addition, Maxwell Displacement has very few parameters and is very comfortable to control.
Instances
Support for Instances means that you can have thousands of high polygon objects in your scene and Maxwell Render will render them using the same amount of memory as if you only had one of those objects in the scene. Instances are extremely useful to reproduce objects such as plants, bricks, stones and furniture.
Matrix 50x50x50
125,000 objects
370,000 polygons per object
Over 46 billion polygons total
MXCL memory used: 230 MB
Pre-voxelization time: 28 seconds
Machine: P4 2.8HT with 1GB RAM
Voxelization multithreading
This can potentially offer great time savings for those with multi-core systems, especially when enabling motion blur. Memory usage during voxelization has also been optimized, which will be most noticeable on 64-bit systems and to a lesser extent on 32-bit systems.
Network improvements
Users now have the option to set a global sampling level (SL) for cooperative renderings so they no longer need to set the SL of each node separately. It’s now also possible to set more than one manager and users can specify managers also by machine name, not just IP.
Sun in Sky dome
It is now possible to use the sunlight from the physical sky together with the Maxwell Render sky dome.
Free Dosch Design HDRIs
Motion blur
Alpha channel
NEXTLIMIT MAXWELL RENDER V1.6 WIN32-XFORCE
Rapidshare
http://rapidshare.com/files/73710987/MaxwellRender_V1.6.part1.rar.html
http://rapidshare.com/files/73710978/MaxwellRender_V1.6.part2.rar.html
(Password) 51render.com
live-sahre
http://www.live-share.com/files/292498/MaxwellRender_V1.6.part1.rar.html
http://www.live-share.com/files/292499/MaxwellRender_V1.6.part2.rar.html
depositfiles
http://depositfiles.com/files/2570655
http://depositfiles.com/files/2570890
51Files
http://www.91files.com/?2Y4CBEHSN946WSZK9M9U
http://www.91files.com/?86NHAR4F4Y80BEWN0BAH
NEXTLIMIT MAXWELL RENDER V1.6 WIN64-XFORCE
Rapidshare
http://rapidshare.com/files/75116625/MaxwellRender_V1.6_x64.part1.rar.html
http://rapidshare.com/files/75116333/MaxwellRender_V1.6_x64.part2.rar.html
51Files
http://www.91files.com/?W3DHQ3SJX1P9QBN3AMY5
http://www.91files.com/?2Z87ZY0Y0YZEU56OEKL5
MAXWELL RENDER 1.6.1 UPDATE (PATCH) 32+64BIT CRACKED
Rapidshare
http://rapidshare.com/files/78294376/NEXTLIMIT_MAXWELL_RENDER_V1.6.1_UPDATE.rar.html
depositfiles
http://depositfiles.com/files/2799725
megaupload
http://www.megaupload.com/?d=MBACKWLE
filefactory
http://www.filefactory.com/file/777a6c
zshare
http://www.zshare.net/download/5824774d19c372/
Plugins
http://www.maxwellrender.com/   (download/plugins)
