Новости плагинов для 3dMax
На сайте c 16.03.2010
SnowFlowPro 1.8 released
SnowFlowPro is a 3D Studio Max plugin that creates realistic snow with ease! You just pick your desired objects and SnowFlowPro does the snow for you! Let the snow fall on your 3D objects and scenes with the click of a button. A variety of parameters ensures that you get the desired results in every situation.
features
self-explaining user interface with integrated help
one-click-solution in most standard situations
multiple snow methods for different needs
advanced settings to get the best out of SnowFlow
different reality levels to control object interference
preset system for a faster workflow
full control over the calculated mesh
network rendering with any network rendering solution
system unit check and conversion to achieve full snow details
autoTune options for better performance
caching system to prevent unnecessary recalculations
"SnowPlug" to stick objects into snow surfaces
"SnowPrint" to make footprints and things like that
доп инфо и демо здесь: http://www.zwischendrin.com/ru/detail/261
Хочу обратить внимание на новый плагин.Пока его можно только купить у автора.
http://www.mariussilaghi.com/projection_painter.htm
Color Tools
http://www.vizpark.com/shop/color-tools/
Extract and combine colors …
Whenever you tried to get color variations on objects you were probably encountered with picking different colors from photos and assigning them to materials and objects to get more variation. What a tedious task!
Color Extract extracts up to 100 colors from any photo and randomly assigns them to objects, object elements or even procedural maps in 3Ds Max. Just load any photo, extract colors and render. It has never been faster before to create or exchange multiple colors at once. And it has never been easier to exchange and use multiple natural colors from photos before. Color Extract is especially useful, but not limited, to natural elements like grass, leaves of a tree, stones, sand, clouds, and many more.
Color Combine combines three different maps into one map where each map represents one color channel (RGB). This way it
На сайте c 13.11.2010
Пенза
Все круто, но можно пару слов о действии плагина, для чего и где использовать.
Платный или нет, есть ли кряк уже или только вышел?)
А то подобной инфы много, а толку от нее мало, время деньги, и все читать, искать и разбираться - смысла нет.
Вот это да!!! Все написано, ссылка на сайт дана,был бы бесплатным или сломаным был бы в другой теме,если вам лень учить английский язык воспользуйтесь гугл переводчиком.Остальное на сайте производителей. Мое время тоже не бесконечно !!!!
На сайте c 22.05.2007
Могилев, Беларусь
эти бы плагины да вылеченные
Form v1.0 from Marius Silaghi
Modeling for human beings Form is a new modeling system for 3ds Max that allows to quickly and easily create models.
It contains a Form modifier, a Form Sphere helper and a Form Tools script.
•It helps you model faster then with traditional box or edge extrusion methods.
•It frees you from worrying about topology.
•It allows you to spend more time expressing your creativity
•It gives you the ability to send the model to a sculpting application or continue editing it with traditional modeling methods.
•It allows you to quickly tweak the form and shape of your model
•It makes modeling fun.
http://www.mariussilaghi.com/form.htm
На сайте c 18.06.2008
Lemberg
думаю, что как только на "персиях" итп...появятся...
или уважаемые коллеги выпросят прямо у иксфорсовцев..
тот-час тут все обьявится.
но я хоть и надеюсь на других, сам тем не менее, стараюсь хоть 10 - 20 мин. раз в день или в два...
прошерстить тырнет...
Да к стати ктонибудь знает, как перекомпилировать плуги с старых версий макса...на ноые?
в частности исчу дигимэйшн лайтнинг...для 2010- 2012...х64.
Lemberg
Form v1.0 есть на персидских торентах ))))
На сайте c 16.04.2008
Пять новых плагинов для 3ds Max от Marius Silaghi.
Плагин Shell Pro - предназначен для создания геометрических оболочек c меньшим количеством самопересечений. Плагин представляет собой улучшенный вариант собственного модификатора Shell в 3ds Max. Как и его тёзка, плагин преобразует поверхность сетки в твёрдую оболочку, например при утолщении поверхности для 3D печати, но предназначен для создания меньшего количества самопересечений. Плагин также предоставляет новые возможности для снятия фасок, скругления и снятия фасок с краев оболочки.
Relax Pro - сглаживание сеток без потери объёма или слишком большого количества деталей поверхности.
Push Pro - помогает создавать более "худые" или "толстые" варианты ваших персонажей. Также как и предыдущий плагин - это более интеллектуальная версия модификаторв Push из 3ds Max, смещающего вершины сетки внутрь или наружу. Как и с предыдущем плагином, этот создаёт меньше самопересечений, нежели его аналог, даже при довольно экстремальных настройках и гораздо лучше справляется с сохранением деталей поверхности.
Contrast Pro - повышение резкости 3D сканов низкого качества или кэшей моделирования с низким разрешением.
Path Deform Pro - деформируйте сетку без самопересечения.
Все плагины совместимы с 64 разрядной 3ds Max 2013 и выше. Стоимость Contrast Pro и Push Pro составляет 30 евро. Path Deform Pro, Relax Pro и Shell Pro стоят 40 евро.
Источник: render.ru
