SnowFlow
Pro 1.8 released
SnowFlowPro is a 3D Studio Max plugin that creates realistic snow with ease! You just pick your desired objects and SnowFlowPro does the snow for you! Let the snow fall on your 3D objects and scenes with the click of a button. A variety of parameters ensures that you get the desired results in every situation.
features
self-explaining user interface with integrated help
one-click-solution in most standard situations
multiple snow methods for different needs
advanced settings to get the best out of SnowFlow
different reality levels to control object interference
preset system for a faster workflow
full control over the calculated mesh
network rendering with any network rendering solution
system unit check and conversion to achieve full snow details
autoTune options for better performance
caching system to prevent unnecessary recalculations
"SnowPlug" to stick objects into snow surfaces
"SnowPrint" to make footprints and things like that
доп инфо и демо здесь:
http://www.zwischendrin.com/ru/detail/261
