Wolh 2016/3/8:15:09:30 Анна ANN === Setup started on ANN by Анна ===2016/3/8:15:09:30 Анна ANN Path_Length: 1512016/3/8:15:09:30 Анна ANN Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US2016/3/8:15:09:30 Анна ANN Launch 2016/3/8:15:09:30 Анна ANN CommandLine /PK 128F1 /SN 900-69646409 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US_Setup.exe?dummy=0" 2016/3/8:15:09:30 Анна ANN Path_Length: 1512016/3/8:15:09:30 Анна ANN Current Directory C:\Users\0D04~1\AppData\Local\Temp\_AI550A.tmp2016/3/8:15:10:22 Анна ANN === Setup ended ===2016/3/8:15:09:32 Анна ANN === Setup started on ANN by Анна ===2016/3/8:15:09:32 Анна ANN Path_Length: 1512016/3/8:15:09:32 Анна ANN Current Directory C:\Users\0D04~1\AppData\Local\Temp\_AI550A.tmp2016/3/8:15:09:32 Анна ANN Launch 2016/3/8:15:10:04 Анна ANN Download Play SETUP_CONFIG
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/SETUP_x64.tar.lzma22016/3/8:15:10:21 Анна ANN Download Complete SETUP_CONFIG
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/SETUP_x64.tar.lzma22016/3/8:15:10:22 Анна ANN PageOpen LaunchDialog 2016/3/8:15:12:28 Анна ANN PageOpen LicenseDialog 2016/3/8:15:12:28 Анна ANN PageOpen ProductInfoDialog 2016/3/8:15:12:28 Анна ANN PageOpen ProductSelectionDialog2 2016/3/8:15:12:32 Анна ANN PageOpen FullProgressDialog 2016/3/8:15:12:32 Анна ANN Download Play VCREDIST2005SP1ATLX86
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/VCREDIST2005SP1ATLX86.tar.lzma22016/3/8:15:12:34 Анна ANN Download Complete VCREDIST2005SP1ATLX86
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/VCREDIST2005SP1ATLX86.tar.lzma22016/3/8:15:12:34 Анна ANN Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\0D04~1\AppData\Local\Temp\vcredist_x86_2005.log"" "2016/3/8:15:13:03 Анна ANN Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2016/3/8:15:13:03 Анна ANN Download Play VCREDIST2005SP1ATLX64
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/VCREDIST2005SP1ATLX64.tar.lzma22016/3/8:15:13:05 Анна ANN Download Complete VCREDIST2005SP1ATLX64
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/VCREDIST2005SP1ATLX64.tar.lzma22016/3/8:15:13:05 Анна ANN Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\0D04~1\AppData\Local\Temp\vcredist_x64_2005.log"" "2016/3/8:15:13:22 Анна ANN Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded 2016/3/8:15:13:22 Анна ANN Download Play VCREDIST2008SP1X86
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/VCREDIST2008SP1X86.tar.lzma22016/3/8:15:13:25 Анна ANN Download Complete VCREDIST2008SP1X86
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/VCREDIST2008SP1X86.tar.lzma22016/3/8:15:13:25 Анна ANN Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q2016/3/8:15:13:41 Анна ANN Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2016/3/8:15:13:41 Анна ANN Download Play VCREDIST2008SP1X64
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/VCREDIST2008SP1X64.tar.lzma22016/3/8:15:13:44 Анна ANN Download Complete VCREDIST2008SP1X64
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/VCREDIST2008SP1X64.tar.lzma22016/3/8:15:13:44 Анна ANN Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q2016/3/8:15:14:00 Анна ANN Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2016/3/8:15:14:00 Анна ANN Download Play DIRECTX
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/DIRECTX.tar.lzma22016/3/8:15:14:42 Анна ANN Download Complete DIRECTX
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/DIRECTX.tar.lzma22016/3/8:15:14:42 Анна ANN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\DirectX\DXSETUP.exe" /silent2016/3/8:15:16:07 Анна ANN Install DirectX® Runtime Succeeded 2016/3/8:15:16:07 Анна ANN Download Play CM
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CM.tar.lzma22016/3/8:15:16:36 Анна ANN Download Complete CM
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CM.tar.lzma22016/3/8:15:16:36 Анна ANN Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/3/8:15:16:52 Анна ANN Install Autodesk® Material Library 2014 Succeeded 2016/3/8:15:16:52 Анна ANN Download Play CMILB
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILB.tar.lzma22016/3/8:15:17:35 Анна ANN Download Complete CMILB
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILB.tar.lzma22016/3/8:15:17:35 Анна ANN Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/3/8:15:17:46 Анна ANN Install Autodesk® Material Library 2014 - Base Image Library Succeeded 2016/3/8:15:17:46 Анна ANN Download Play CMILM
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILM.tar.lzma22016/3/8:15:22:52 Анна ANN Download Aborted CMILM
{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILM.tar.lzma22016/3/8:15:22:52 Анна ANN Install Autodesk® Material Library 2014 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=16032016/3/8:15:23:02 Анна ANN Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded 2016/3/8:15:23:18 Анна ANN Rollback Autodesk® Material Library 2014 Succeeded 2016/3/8:15:23:18 Анна ANN Rollback DirectX® Runtime Failed Failure is ignored, Result=16192016/3/8:15:23:19 Анна ANN Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=16192016/3/8:15:23:19 Анна ANN Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=16192016/3/8:15:23:19 Анна ANN Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=16192016/3/8:15:23:19 Анна ANN Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=16192016/3/8:15:23:19 Анна ANN PageOpen InstallCompleteDialog 2016/3/8:15:23:55 Анна ANN === Setup ended ===2016/3/8:15:26:50 Анна ANN === Setup started on ANN by Анна ===2016/3/8:15:26:50 Анна ANN Path_Length: 1512016/3/8:15:26:50 Анна ANN Current Directory D:\3ds Max 20142016/3/8:15:26:50 Анна ANN Launch 2016/3/8:15:26:50 Анна ANN CommandLine 2016/3/8:15:26:50 Анна ANN Path_Length: 1512016/3/8:15:26:50 Анна ANN Current Directory C:\Users\0D04~1\AppData\Local\Temp\_AI3233.tmp2016/3/8:15:27:19 Анна ANN === Setup ended ===2016/3/8:15:26:56 Анна ANN === Setup started on ANN by Анна ===2016/3/8:15:26:56 Анна ANN Path_Length: 1512016/3/8:15:26:56 Анна ANN Current Directory C:\Users\0D04~1\AppData\Local\Temp\_AI3233.tmp2016/3/8:15:26:56 Анна ANN Launch 2016/3/8:15:27:19 Анна ANN PageOpen LaunchDialog 2016/3/8:15:27:21 Анна ANN PageOpen LicenseDialog 2016/3/8:15:27:26 Анна ANN PageOpen ProductInfoDialog 2016/3/8:15:27:56 Анна ANN PageOpen ProductSelectionDialog2 2016/3/8:15:27:58 Анна ANN PageOpen FullProgressDialog 2016/3/8:15:27:58 Анна ANN Installing DirectX® Runtime: "D:\3ds Max 2014\3rdParty\DirectX\DXSETUP.exe" /silent2016/3/8:15:28:44 Анна ANN Install DirectX® Runtime Succeeded 2016/3/8:15:28:44 Анна ANN Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="D:\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/3/8:15:29:03 Анна ANN Install Autodesk® Material Library 2014 Succeeded 2016/3/8:15:29:03 Анна ANN Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="D:\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/3/8:15:29:26 Анна ANN Install Autodesk® Material Library 2014 - Base Image Library Succeeded 2016/3/8:15:29:26 Анна ANN Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="D:\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/3/8:15:30:29 Анна ANN Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2016/3/8:15:30:31 Анна ANN Installing Autodesk® 3ds Max 2014: TRANSFORMS="C:\Users\0D04~1\AppData\Local\Temp\_AI3233.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\3ds Max 2014\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/3/8:15:32:44 Анна ANN Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=16032016/3/8:15:32:54 Анна ANN Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2016/3/8:15:33:03 Анна ANN Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded 2016/3/8:15:33:21 Анна ANN Rollback Autodesk® Material Library 2014 Succeeded 2016/3/8:15:33:21 Анна ANN Rollback DirectX® Runtime Failed Failure is ignored, Result=16192016/3/8:15:33:22 Анна ANN PageOpen InstallCompleteDialog 2016/3/8:15:42:41 Анна ANN === Setup ended ===2016/3/8:16:19:34 Анна ANN === Setup started on ANN by Анна ===2016/3/8:16:19:34 Анна ANN Path_Length: 1512016/3/8:16:19:34 Анна ANN Current Directory D:\3ds Max 20142016/3/8:16:19:34 Анна ANN Launch 2016/3/8:16:19:34 Анна ANN CommandLine 2016/3/8:16:19:34 Анна ANN Path_Length: 1512016/3/8:16:19:34 Анна ANN Current Directory C:\Users\0D04~1\AppData\Local\Temp\_AI78A8.tmp2016/3/8:16:19:39 Анна ANN === Setup ended ===2016/3/8:16:19:34 Анна ANN === Setup started on ANN by Анна ===2016/3/8:16:19:34 Анна ANN Path_Length: 1512016/3/8:16:19:34 Анна ANN Current Directory C:\Users\0D04~1\AppData\Local\Temp\_AI78A8.tmp2016/3/8:16:19:34 Анна ANN Launch 2016/3/8:16:19:38 Анна ANN PageOpen LaunchDialog 2016/3/8:16:19:40 Анна ANN PageOpen LicenseDialog 2016/3/8:16:19:42 Анна ANN PageOpen ProductInfoDialog 2016/3/8:16:20:19 Анна ANN PageOpen ProductSelectionDialog2 2016/3/8:16:20:24 Анна ANN PageOpen FullProgressDialog 2016/3/8:16:20:24 Анна ANN Installing DirectX® Runtime: "D:\3ds Max 2014\3rdParty\DirectX\DXSETUP.exe" /silent2016/3/8:16:21:00 Анна ANN Install DirectX® Runtime Succeeded 2016/3/8:16:21:00 Анна ANN Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="D:\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/3/8:16:21:20 Анна ANN Install Autodesk® Material Library 2014 Succeeded 2016/3/8:16:21:20 Анна ANN Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="D:\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/3/8:16:21:32 Анна ANN Install Autodesk® Material Library 2014 - Base Image Library Succeeded 2016/3/8:16:21:32 Анна ANN Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="D:\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/3/8:16:22:37 Анна ANN Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2016/3/8:16:22:39 Анна ANN Installing Autodesk® 3ds Max 2014: TRANSFORMS="C:\Users\0D04~1\AppData\Local\Temp\_AI78A8.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\3ds Max 2014\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2016/3/8:16:24:04 Анна ANN Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=16032016/3/8:16:24:14 Анна ANN Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2016/3/8:16:24:24 Анна ANN Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded 2016/3/8:16:24:44 Анна ANN Rollback Autodesk® Material Library 2014 Succeeded 2016/3/8:16:24:44 Анна ANN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
