3ddragon vray batch render - vidayot chornuyu kartinku!
На сайте c 14.10.2010
stavlyu neskolko scen na etu progu, s neskolkimi kamerami, nachinayetsa render, idyot vsyo normalno, a potom kogda smotrish v rezultat - sohranyonniy fayl kartinka vsya chornaya.
inogda bivayet sohranyayetsa vsyo normalno. a inogda chornaya kartinka.
sohranyayu libo v tif 300 dpi, libo v png, a posledneye vremya vse fayli chorniye vihodyat.
znayushiye ludi dayte solution pleez. Dobrom vsem!
oh kajis nashol otvet, kajis u menya malo RAM'a na kompe,
vsem komu interesno, mogut pochitat sledusheyye, (nashol na kakomtosayte):
V-ray can't create bitmap is due to lack of memory to save the image for some reason.
the easiest way to solve this issue is to switch to 64bit OS as 64bit OS able to fully utilize the RAM.
but if you insist to stick with 32bit OS, this is what you can do.
1- go render setup, under "v-ray" tab > under "v-ray:frame buffer" roll out
2- check "enable built-in frame buffer"
3- uncheck "render to memory frame buffer", "get resolution from MAX" and "save separate render channels".
4- Enter your desire width and height of the image/render resolution.
5- Check "Render to V-Ray raw image file"
6- Check "Generate preview" (optional, but personally i check it)
7- Browse and save to a location
8a- upon finish render and saved, u can convert your .vrimg by using "VRImg to OpenEXR converter" which is under start>all programs>chaos group>ur vray ver>tools
8b- or another way which is so much prefer by me is to launch your 3Ds Max, click File>View Image File... look for your image. it will appear as if u just rendered finish. save the image as another format from there.
done...
below are some screen shoot for your references
На сайте c 11.03.2007
Болгария
Щас тебя скушают кажетса за латиницу. Перепеши на кирлицу если можеш, а то врядли ответ получиш. Я лично не стал читать- глаза ломать.
защем кушать.. просто никто не ответит и все..
