![2ue5fs8.png](http://i24.tinypic.com/2ue5fs8.png)
Autodesk® 3ds Max® software is a powerful, integrated 3D modeling, animation, and rendering application. Its easy-to-learn environment enables artists to quickly ramp up for production. 3ds Max is used by film and video artists, game developers, multimedia designers (print and web), design visualization professionals, and 3D enthusiasts to achieve stunning results in less time. 3ds Max is the leader in 3D animation for game development, design visualization, visual effects, and education.
Create rich and complex design visualization. Generate realistic characters for a top-selling game. Bring 3D effects to the big screen. Autodesk® 3ds Max® 2008 3D modeling, animation, and rendering software helps design visualization professionals, game developers, and visual effects artists maximize their productivity by streamlining the process of working with complex scenes.
Key New Features and Enhancements:
Accelerated Performance
The integration of new technology into the software’s Adaptive Degradation System improves interactive performance by automatically simplifying scene display to meet a user-defined target frame rate. You control how 3ds Max adjusts scene display—whether the smallest objects are hidden, or distant objects have less detail, etc.—and 3ds Max calculates how best to achieve it. When combined with the new Direct3D® mesh caching that groups objects by materials, the result is that tens of thousands of objects can be just as interactive as ten objects. In addition, loading, arrays, Autodesk® FBX® and OBJ export, and other areas of the software perform significantly faster.
Scene Explorer Scene Management
3ds Max 2008 delivers Scene Explorer, a robust new tool that provides you with a hierarchical view of scene data and fast scene analysis, along with editing tools that facilitate working with even the most complex, object-heavy scenes. Scene Explorer gives you the ability to sort, filter, and search a scene by any object type or property (including metadata), with stackable filtering, sorting, and searching criteria. This new tool also enables you to save and store multiple Explorer instances and to link, unlink, rename, hide, freeze, and delete objects, regardless of what objects are currently selected in the scene. You can also configure columns to display and edit any object property, and because this feature is scriptable and SDK extendable, you can use callbacks to add custom column definitions.
Review
This powerful new toolset gives you immediate feedback on various render settings, enabling you to iterate rapidly. This means you can now quickly hone in on your desired look without waiting for a software render—perfect for over-the-shoulder client/boss feedback sessions and other iterative workflows. Based on the latest game engine technology, Review delivers interactive viewport previews of shadows (including self-shadowing and up to 64 lights simultaneously), the 3ds Max sun/sky system, and mental ray® Architectural and Design material settings.
MAXScript ProEditor
3ds Max 2008 marks the debut of the new MAXScript ProEditor. This intuitive new interface for working with MAXScript includes multilevel undo functionality; fast, high-quality code colorization; rapid opening of large documents; line number display; regular expressions in search/replace; folding of sections of the script; support for user customization; and many other features.
Enhanced DWG Import
3ds Max 2008 delivers faster, more accurate importing of DWG™ files. Significantly improved memory management enables you to import large, complex scenes with multiple objects in considerably less time. Improved support for material assignment and naming, solid object import, and normals management facilitate working with software products such as Revit Architecture 2008. Plus, a new Select Similar feature identifies all objects in an imported DWG scene that contain characteristics similar to those of a selected object. This capability lets you select and edit multiple imported objects simultaneously—dramatically streamlining DWG-based workflows.
Artist-Friendly Modeling Options
3ds Max 2008 gives you a more streamlined, artist-friendly modeling workflow through a collection of hands-on modeling options that let you focus more on the creative process. These options include selection previewing and the ability to have existing modeling hotkeys and pivots become temporary overrides.
Biped Enhancements
This latest release provides you with new levels of flexibility with regard to your Biped rigs. A new Xtras tool lets you create and animate extraneous Biped features anywhere on your rig (for example, wings or additional facial bones) and save them as BIP files. These files are supported in Mixer and Motion Flow, as well as in Layers, where new layering functionality enables BIP files to be saved as offsets from each layer to isolate character motion. As a result, each layer can be saved as its own asset for export into a game.
Expanded Platform Support
3ds Max 2008 is the first full release of the software officially compatible with Microsoft® Windows Vista™ 32-bit and 64-bit operating systems and the Microsoft DirectX® 10 platform.
3ds Max 2008 includes toolsets for:
Modeling and texturing
Animation
Visual effects
Rendering
Hair and fur
Cloth
Asset management and collaboration
plus
3ds Max API/SDK and MAXScripts
Tutorials and documentation
Цитата
Installation:
unpack, burn or mount & install.
check Crack/install.txt on DVD1 http://rapidshare.com/files/63263204/AtdskMx2k8iso.part01.rar
http://rapidshare.com/files/63263714/AtdskMx2k8iso.part02.rar
http://rapidshare.com/files/63263226/AtdskMx2k8iso.part03.rar
http://rapidshare.com/files/63263249/AtdskMx2k8iso.part04.rar
http://rapidshare.com/files/63263641/AtdskMx2k8iso.part05.rar
http://rapidshare.com/files/63264409/AtdskMx2k8iso.part06.rar
http://rapidshare.com/files/63264509/AtdskMx2k8iso.part07.rar
http://rapidshare.com/files/63264506/AtdskMx2k8iso.part08.rar
http://rapidshare.com/files/63264465/AtdskMx2k8iso.part09.rar
http://rapidshare.com/files/63264405/AtdskMx2k8iso.part10.rar
http://rapidshare.com/files/63265064/AtdskMx2k8iso.part11.rar
http://rapidshare.com/files/63265048/AtdskMx2k8iso.part12.rar
http://rapidshare.com/files/63265083/AtdskMx2k8iso.part13.rar
http://rapidshare.com/files/63265301/AtdskMx2k8iso.part14.rar
http://rapidshare.com/files/63265160/AtdskMx2k8iso.part15.rar
http://rapidshare.com/files/63267155/AtdskMx2k8iso.part16.rar
http://rapidshare.com/files/63267236/AtdskMx2k8iso.part17.rar
http://rapidshare.com/files/63267193/AtdskMx2k8iso.part18.rar
http://rapidshare.com/files/63267179/AtdskMx2k8iso.part19.rar
http://rapidshare.com/files/63267149/AtdskMx2k8iso.part20.rar
http://rapidshare.com/files/63267997/AtdskMx2k8iso.part21.rar
http://rapidshare.com/files/63267954/AtdskMx2k8iso.part22.rar
http://rapidshare.com/files/63267976/AtdskMx2k8iso.part23.rar
http://rapidshare.com/files/63267758/AtdskMx2k8iso.part24.rar
http://rapidshare.com/files/63267784/AtdskMx2k8iso.part25.rar
http://rapidshare.com/files/63268934/AtdskMx2k8iso.part26.rar
http://rapidshare.com/files/63268951/AtdskMx2k8iso.part27.rar
http://rapidshare.com/files/63268896/AtdskMx2k8iso.part28.rar
http://rapidshare.com/files/63271539/AtdskMx2k8iso.part29.rar
http://rapidshare.com/files/63268987/AtdskMx2k8iso.part30.rar
http://rapidshare.com/files/63268954/AtdskMx2k8iso.part31.rar
зеркало (не проверял)http://rapidshare.com/files/63018465/nam08z.r00
http://rapidshare.com/files/63018461/nam08z.r01
http://rapidshare.com/files/63018462/nam08z.r02
http://rapidshare.com/files/63018454/nam08z.r03
http://rapidshare.com/files/63018843/nam08z.r04
http://rapidshare.com/files/63018909/nam08z.r05
http://rapidshare.com/files/63018908/nam08z.r06
http://rapidshare.com/files/63018912/nam08z.r07
http://rapidshare.com/files/63018907/nam08z.r08
http://rapidshare.com/files/63019236/nam08z.r09
http://rapidshare.com/files/63019299/nam08z.r10
http://rapidshare.com/files/63019298/nam08z.r11
http://rapidshare.com/files/63019300/nam08z.r12
http://rapidshare.com/files/63019297/nam08z.r13
http://rapidshare.com/files/63019616/nam08z.r14
http://rapidshare.com/files/63019648/nam08z.r15
http://rapidshare.com/files/63019669/nam08z.r16
http://rapidshare.com/files/63019667/nam08z.r17
http://rapidshare.com/files/63019703/nam08z.r18
http://rapidshare.com/files/63020025/nam08z.r19
http://rapidshare.com/files/63020063/nam08z.r20
http://rapidshare.com/files/63020088/nam08z.r21
http://rapidshare.com/files/63020173/nam08z.r22
http://rapidshare.com/files/63020161/nam08z.r23
http://rapidshare.com/files/63020458/nam08z.r24
http://rapidshare.com/files/63020455/nam08z.r25
http://rapidshare.com/files/63020456/nam08z.r26
http://rapidshare.com/files/63020567/nam08z.r27
http://rapidshare.com/files/63020853/nam08z.r28
http://rapidshare.com/files/63020854/nam08z.r29
http://rapidshare.com/files/63020873/nam08z.r30
http://rapidshare.com/files/63020952/nam08z.r31
http://rapidshare.com/files/63021211/nam08z.r32
http://rapidshare.com/files/63021213/nam08z.r33
http://rapidshare.com/files/63021246/nam08z.r34
http://rapidshare.com/files/63021324/nam08z.r35
http://rapidshare.com/files/63021698/nam08z.r36
http://rapidshare.com/files/63021697/nam08z.r37
http://rapidshare.com/files/63021700/nam08z.r38
http://rapidshare.com/files/63021744/nam08z.r39
http://rapidshare.com/files/63022162/nam08z.r40
http://rapidshare.com/files/63022161/nam08z.r41
http://rapidshare.com/files/63022163/nam08z.r42
http://rapidshare.com/files/63022198/nam08z.r43
http://rapidshare.com/files/63022257/nam08z.r44
http://rapidshare.com/files/63022589/nam08z.r45
http://rapidshare.com/files/63022592/nam08z.r46
http://rapidshare.com/files/63022587/nam08z.r47
http://rapidshare.com/files/63022588/nam08z.r48
http://rapidshare.com/files/63022644/nam08z.r49
http://rapidshare.com/files/63022953/nam08z.r50
http://rapidshare.com/files/63023012/nam08z.r51
http://rapidshare.com/files/63023013/nam08z.r52
http://rapidshare.com/files/63023011/nam08z.r53
http://rapidshare.com/files/63023041/nam08z.r54
http://rapidshare.com/files/63023307/nam08z.r55
http://rapidshare.com/files/63023347/nam08z.r56
http://rapidshare.com/files/63023346/nam08z.r57
http://rapidshare.com/files/63023394/nam08z.r58
http://rapidshare.com/files/63023395/nam08z.r59
http://rapidshare.com/files/63023689/nam08z.r60
http://rapidshare.com/files/63023750/nam08z.r61
http://rapidshare.com/files/63023749/nam08z.r62
http://rapidshare.com/files/63023785/nam08z.r63
http://rapidshare.com/files/63018459/nam08z.rar
Pwd :: NeedZ
