Corona Renderer 5 for 3ds Max - Daily Builds
На сайте c 06.05.2012
Минск
Re: Corona Renderer 5 for 3ds Max - Daily Builds ChangelogNew and improved featuresCorona now uses an improved text rendering used in render stamp and unsupported materials"Setup LightMix" button added to the multiple environment maps setup dialogAdded “Unpacking and installing” message to installer to notify that something is happening after NVIDIA AI denoiser or material library are downloadedCopy to clipboard option added into CIEAdded a warning shown when there is a NaN (invalid pixel value) in the rendered imageInstaller now detects when the selected unpack directory contains any files and asks the user whether to override them or cancel the action[IR] tag was added to VFB title to show that image was rendered with IRCaustics now respect the include/exclude list of lightsChanging render regions now resumes IR which was stopped by pass limitOptimizationsImproved performance of caustics solver in scenes with multiple light sourcesReduced memory used by the caustics solver by up to 30%Faster IR restarts in scenes with sun(s)Performance optimizations - around 7% gain in tested scenesOptimized ColorCorrectTex evaluationSwitched to the latest Embree library. This brings speed improvement (8% for instances), memory reduction (up to 2x reduced for hair, 192 bytes lower consumption per each instance), improved intersection with hair (removes some artifacts)Rewrite of geometry processingThere are significant memory savings, 25-85% of memory used by geometry. Measured e.g. 10GB less memory usage on real scene (from 60 to 50GB)CGEO and standalone format changes slightly. New proxies cannot be opened in older versions. New versions will open all proxiesParsing of scenes should be fasterBugfixesFixed installer reporting incomplete size (e.g. “218.9 MB / 220 MB”) after successfully downloading NVIDIA AI denoiser or material libraryFixed toggleable button wrong colorFixed Proxy animation option “Hide out of range” hiding the proxy too earlyFixed crashes when loading malformed proxy filesFixed crash when NVIDIA AI libraries cannot be loadedFixed Corona to seek Licensing Server on all network interfacesThe "Activate license..." button in System tab in Render Setup now does not need to be clicked multiple times to get the activationThe System tab in Render Setup no longer claims that there is no license when it has been acquired from Licensing server
Ничо так :
-25-85% потребления ОЗУ геометрией
+8% к скорости рендера
Вдвое меньше жора ОЗУ от Волосни
-30% жора ОЗУ каустикой
Ускорили Парсинг сцен (запуск рендера и интерактива)
Минск
но у меня крашит макс
На сайте c 20.07.2015
Ну наконец занялись потреблением памяти, и это очень круто! Рад за коронщиков, апдейт многообещающий :)
главное чтоб ускорили geometry, а не только парсинг
