ГОСТИНАЯ ОТ Autocad к Render
На сайте c 29.12.2010
plans
sections
I started from the plan , I drew the first wall by 2D tools ( line )
add modifier Extrude 395 cm
I drew lines and a rectangle to make the grooves
I choose the rectangle and turn to connect from geometry < compound objects < connect
then I pick the other lines
I choose the wall and turn it to brobolean from geometry < compound objects < brobolean
then I subtracted the connect objects then I got the wall with grooves
then I began to make the wooden parts in the wall
You can see the video here
https://www.youtube.com/watch?v=gULhr6nHR7Q
I continued with the same steps
the grooves again
the door frame
the door
the floor this is very important
I used floor generator to get a good floor tiles
first I drew the line for floor then choose it and run the script
I finished the modeling
the link for modeling
http://www.4shared.com/file/YIVkfKO7/modeling.html
active the vray
medium setting
add sun and vrayplane on the window from outside
add mtl for all the modeling accept glass I add transparent mtl for it
then I render
vray plane = 5
vray plane = 8
i4358_3l.jpg[/img]
night shoot
I change the vray plane color and add light spots
the final render
ore information about details
light
exclude the celing light unit from the light
the light inside the groof
the TV light in front of TV
material
Turn the wall with grooves into edit poly and then rename the polgen
try to get lighter color than in the actual map
the second color
i4500_14.jpg[/img]
wooden mtl
golden mtl
floor mtl
sofa mtl
cloth on the wall
Render setting
more details about connect
