plans
sections![i4287_1.jpg](http://up.cgway.net/out.php/i4287_1.jpg)
I started from the plan , I drew the first wall by 2D tools ( line )
add modifier Extrude 395 cm
![i4296_3.jpg](http://up.cgway.net/out.php/i4296_3.jpg)
![i4299_6.jpg](http://up.cgway.net/out.php/i4299_6.jpg)
I drew lines and a rectangle to make the grooves
![i4300_7.jpg](http://up.cgway.net/out.php/i4300_7.jpg)
I choose the rectangle and turn to connect from geometry < compound objects < connect
then I pick the other lines
I choose the wall and turn it to brobolean from geometry < compound objects < brobolean
then I subtracted the connect objects then I got the wall with grooves
![i4301_8.jpg](http://up.cgway.net/out.php/i4301_8.jpg)
then I began to make the wooden parts in the wall
![i4302_9.jpg](http://up.cgway.net/out.php/i4302_9.jpg)
You can see the video here
https://www.youtube.com/watch?v=gULhr6nHR7Q ![i4307_14.jpg](http://up.cgway.net/out.php/i4307_14.jpg)
I continued with the same steps
![i4308_15.jpg](http://up.cgway.net/out.php/i4308_15.jpg)
![i4310_17.jpg](http://up.cgway.net/out.php/i4310_17.jpg)
![i4313_19.jpg](http://up.cgway.net/out.php/i4313_19.jpg)
