hotfix для 3d max 2008-2009
На сайте c 27.03.2008
На сайте c 02.10.2006
АР Крым Симферополь
ссылки не доступны!
АР Крым Симферополь
Hotfix - Autodesk 3ds Max 2009 - 2008.05.01
ViewCube
ViewCube was causing viewport issues and a possible crash in Windows XP and Vista. This has been fixed.
BackBurner
BackBurner and Command Line rendering would fail when scenes contained the ViewCube. This has been fixed to render the scenes properly.
This hot fix is cumulative and contains all previous hot fixes.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11279116&linkID=9241178
Hotfix - Autodesk 3ds Max 2009 - 2008.04.11
The ProMaterials libraries included within Autodesk 3ds Max and 3ds Max Design 2009 were compiled for SSE2 compatible and newer processors. Some Athlon processors that are within the minimum system requirements for use with 3ds Max 2009 are not SSE2 compatible and the affected libraries have been fixed to work on these systems
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11225370&linkID=9241178
