Installation Failed 2010
На сайте c 06.12.2009
Минск
на работе стоит 3d max 2013 design. По многим причинам нужно дополнительно установить 3d 2010, при начале установки выдает окошко
может у кого есть идеи? гугл не помог
2013/1/17:12:38:07 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:12:38:10 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:12:38:17 admin ADMIN-ПК === Setup ended ===
2013/1/17:12:52:30 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/17:12:52:37 admin ADMIN-ПК === Setup ended ===
2013/1/17:12:53:40 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:12:53:42 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:12:53:49 admin ADMIN-ПК === Setup ended ===
2013/1/17:12:54:49 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/17:12:57:22 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/17:13:35:30 admin ADMIN-ПК === Setup ended ===
2013/1/17:13:35:52 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:13:35:53 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:13:35:55 admin ADMIN-ПК === Setup ended ===
2013/1/17:13:37:10 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/17:13:37:14 admin ADMIN-ПК === Setup ended ===
2013/1/17:13:37:30 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:13:37:33 admin ADMIN-ПК === Setup ended ===
2013/1/17:13:39:17 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/17:13:39:57 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/17:13:40:03 admin ADMIN-ПК === Setup ended ===
2013/1/17:13:43:58 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:13:43:59 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:13:44:04 admin ADMIN-ПК === Setup ended ===
2013/1/17:13:44:44 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/17:13:44:47 admin ADMIN-ПК === Setup ended ===
2013/1/23:12:13:28 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/23:12:13:31 admin ADMIN-ПК === Setup ended ===
2013/1/23:12:15:35 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/23:12:16:50 admin ADMIN-ПК === Setup ended ===
2013/1/23:12:17:20 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/23:12:17:23 admin ADMIN-ПК === Setup ended ===
2013/1/23:12:19:15 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/23:12:27:50 admin ADMIN-ПК === Setup ended ===
На сайте c 15.08.2007
Ukraine, Kiev
Покажите что в логе пишет.
На сайте c 10.06.2008
А система точно х64 или ты на х32 версию для х64 ставишь?
Минск
точно 64, предотвращая вопрос скажу что пробывал и 32 и 64 ) все одно и то же.
на соседнем точно таком же ошибки не выдало, т.ч. проблемка не в сборке 3д пакета. а скорее в ПО
хм...ну попробуй отключить контроль учеток полностью (если ещене отключен) и запускать инсталляшки все от админа, у 3д Макса такой проблемы не помню, но вот у ВРайки 1.5.хх была проблема, что он не ставился, если даже под админской учеткой не выбрать "запустить от имени администратора".
Ну и как панацея от всех бед - переустанови Винду, если не поможет, тогда качай Убунту и работай в Блендере)
Ukraine, Kiev
Не стает C++ Redistributable, может билд самого инстала кривой, Попробуйте другую версию макса поставить, тот-же 2010 только чтоб сборка другая была.
Попробуйте запустить от имени админа.
Минск
1)ответ выше
2) не помогло
На сайте c 21.07.2008
Попробуй удалить вручную Microsoft Visual C++ 2005(?) Redistributable и поставить тоже, скачай сам с офф сайта.
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/m-p/3382347/highlight/true#M43712
