не конвертируется сцена в поли (для прокси)
На сайте c 01.12.2014
ВОТ ТАКАЯ ОШИБКА ВЫЛАЗИЕТ
/*Convert To: MacroScript File 12 dec 2003, Pierre-Felix Breton, added product switcher: this macro file can be shared with all Discreet products This script enables all surface conversions through Macroscripts.--***********************************************************************************************-- MODIFY THIS AT YOUR OWN RISK-- */MacroScript Collapse_Stack enabledIn:#("max", "viz", "vizr") --pfb: 2003.12.12 added product switch ButtonText:~COLLAPSE_STACK_BUTTONTEXT~ Category:~COLLAPSE_STACK_CATEGORY~ internalCategory:"Modifier Stack" Tooltip:~COLLAPSE_STACK_TOOLTIP~ -- Needs Icon --Icon:#("Max_edit_modifiers",1)( On isEnabled return Try(Filters.Are_Modifiers_Applied())Catch() On isVisible return Try(Filters.Are_Modifiers_Applied())Catch() On Execute Do ( Undo on ( if SubObjectLevel == undefined then Max Modify Mode For obj in selection do ( Try(CollapseStack obj)Catch() ) ) ) )MacroScript Modify_Mode enabledIn:#("max", "viz", "vizr") --pfb: 2003.12.12 added product switch ButtonText:~MODIFY_MODE_BUTTONTEXT~ Category:~MODIFY_MODE_CATEGORY~ internalCategory:"Modifier Stack" Tooltip:~MODIFY_MODE_TOOLTIP~ -- Needs Icon --Icon:#("Max_edit_modifiers",1)( On isEnabled return (Try(getCommandPanelTaskMode() != #modify)Catch()) On isVisible return (Try(getCommandPanelTaskMode() != #modify)Catch()) On Execute Do ( Max Modify Mode ) )MacroScript Create_Mode enabledIn:#("max", "viz") --pfb: 2003.12.12 added product switch ButtonText:~CREATE_MODE_BUTTONTEXT~ Category:~CREATE_MODE_CATEGORY~ internalCategory:"Modifier Stack" Tooltip:~CREATE_MODE_TOOLTIP~ -- Needs Icon --Icon:#("Max_edit_modifiers",1)( On isEnabled return (Try(getCommandPanelTaskMode() != #create)Catch()) On isVisible return (Try(getCommandPanelTaskMode() != #create)Catch()) On Execute Do ( Max Create Mode ) )MacroScript Convert_to_Mesh enabledIn:#("max", "viz", "vizr") --pfb: 2003.12.12 added product switch ButtonText:~CONVERT_TO_MESH_BUTTONTEXT~ Category:~CONVERT_TO_MESH_CATEGORY~ internalCategory:"Modifier Stack" Tooltip:~CONVERT_TO_MESH_TOOLTIP~ Icon:#("Max_edit_modifiers",1)( On isEnabled return (Try(Selection.count != 0 and CanConvertTo Selection[1] Mesh)Catch()) On isVisible return (Try(Selection.count != 0 and CanConvertTo Selection[1] Mesh)Catch()) On Execute Do ( SuspendEditing() for obj in selection do ( Try(ConvertToMesh obj)Catch() ) ResumeEditing() Max modify mode ))MacroScript Convert_to_Patch enabledIn:#("max", "viz") --pfb: 2003.12.12 added product switch ButtonText:~CONVERT_TO_PATCH_BUTTONTEXT~ Category:~CONVERT_TO_PATCH_CATEGORY~ internalCategory:"Modifier Stack" Tooltip:~CONVERT_TO_PATCH_TOOLTIP~ Icon:#("Max_edit_modifiers",2)( On isEnabled return (Try(Selection.count != 0 and CanConvertTo Selection[1] Editable_Patch)Catch()) On isVisible return (Try(Selection.count != 0 and CanConvertTo Selection[1] Editable_Patch)Catch()) On Execute Do ( SuspendEditing() for obj in selection do ( Try(ConvertTo obj Editable_Patch)Catch() ) ResumeEditing() Max modify mode ))MacroScript Convert_to_Spline enabledIn:#("max", "viz", "vizr") --pfb: 2003.12.12 added product switch ButtonText:~CONVERT_TO_SPLINE_BUTTONTEXT~ Category:~CONVERT_TO_SPLINE_CATEGORY~ internalCategory:"Modifier Stack" Tooltip:~CONVERT_TO_SPLINE_TOOLTIP~ Icon:#("Max_edit_modifiers",11)( On isEnabled return (Try(Selection.count != 0 and CanConvertTo Selection[1] SplineShape)Catch()) On isVisible return (Try(Selection.count != 0 and CanConvertTo Selection[1] SplineShape)Catch()) On Execute Do ( SuspendEditing() for obj in selection do ( Try(ConvertToSplineShape obj)Catch() ) ResumeEditing() Max modify mode ))MacroScript Convert_to_NURBS enabledIn:#("max", "viz") --pfb: 2003.12.12 added product switch ButtonText:~CONVERT_TO_NURBS_BUTTONTEXT~ Category:~CONVERT_TO_NURBS_CATEGORY~ internalCategory:"Modifier Stack" Tooltip:~CONVERT_TO_NURBS_TOOLTIP~ Icon:#("Max_edit_modifiers",16)( -- only check the first item in the selection array. Fast but not very robust. On isEnabled return (Try(Selection.count != 0 and CanConvertTo Selection[1] NURBSSurface)Catch()) -- only check the first item in the selection array. Fast but not very robust. On isVisible return (Try(Selection.count != 0 and CanConvertTo Selection[1] NURBSSurface)Catch()) On Execute Do ( SuspendEditing() -- Ensure each item can be converted before attempting it. for obj in selection where (CanConvertTo obj NurbsSurface) do ( ConvertToNURBSSurface obj ) ResumeEditing() Max modify mode ))MacroScript Convert_to_PolyenabledIn:#("max", "viz") --pfb: 2003.12.12 added product switch ButtonText:~CONVERT_TO_POLY_BUTTONTEXT~ Category:~CONVERT_TO_POLY_CATEGORY~ internalCategory:"Modifier Stack" Tooltip:~CONVERT_TO_POLY_TOOLTIP~ Icon:#("Max_edit_modifiers",16)( On isEnabled return (Try(Selection.count != 0 and CanConvertTo Selection[1] Editable_Poly)Catch()) On isVisible return (Try(Selection.count != 0 and CanConvertTo Selection[1] Editable_Poly)Catch()) On Execute Do ( SuspendEditing() Try( for obj in selection do ( Try(ConvertTo obj Editable_Poly)Catch() ) Max modify mode ) Catch() ResumeEditing() ))MacroScript Convert_to_deformable_gPolyenabledIn:#("max", "viz") --pfb: 2003.12.12 added product switch ButtonText:~CONVERT_TO_DEFORMABLE_GPOLY_BUTTONTEXT~ Category:~CONVERT_TO_DEFORMABLE_GPOLY_CATEGORY~ internalCategory:"Modifier Stack" Tooltip:~CONVERT_TO_DEFORMABLE_GPOLY_TOOLTIP~ Icon:#("Max_edit_modifiers",16)( On isEnabled return (Try(Selection.count != 0 and CanConvertTo Selection[1] deformable_gPoly)Catch()) On isVisible return (Try(Selection.count != 0 and CanConvertTo Selection[1] deformable_gPoly)Catch()) On Execute Do ( SuspendEditing() Try( for obj in selection do ( Try(ConvertTo obj deformable_gPoly) Catch() ) Max modify mode ) Catch() ResumeEditing() ))-- Added by NH as part of Grab bag feature. Provide an Action item for Show End Result in modifier stackMacroScript Show_End_Result_ToggleenabledIn:#("max", "viz", "vizr") --pfb: 2003.12.11 added product switch category:~SHOW_END_RESULT_TOGGLE_CATEGORY~ internalCategory:"Modifier Stack" ButtonText:~SHOW_END_RESULT_TOGGLE_BUTTONTEXT~ tooltip:~SHOW_END_RESULT_TOGGLE_TOOLTIP~ ( on execute do showEndResult = not showEndResult -- action to execute - toggle the setting on isEnabled return true -- greyed out if false on isChecked return showEndResult -- checked if true on isVisible return true -- visible if true)-- Added by NH as part of Maintain Custom Attributes on Stack Collapse feature. Provide an Action item for togglng the Survive flag stateMacroScript Maintain_Custom_Attributes_On_StackCollapse_ToggleenabledIn:#("max", "viz", "vizr") --pfb: 2003.12.11 added product switch category:~MAINTAIN_CUSTOM_ATTRIBUTES_ON_STACKCOLLAPSE_TOGGLE_CATEGORY~ internalCategory:"Modifier Stack" ButtonText:~MAINTAIN_CUSTOM_ATTRIBUTES_ON_STACKCOLLAPSE_TOGGLE_BUTTONTEXT~ tooltip:~MAINTAIN_CUSTOM_ATTRIBUTES_ON_STACKCOLLAPSE_TOGGLE_TOOLTIP~ ( on execute do custattribCollapsemanager.surviveState = not custattribCollapsemanager.surviveState -- action to execute - toggle the setting on isEnabled return true -- greyed out if false on isChecked return custattribCollapsemanager.surviveState -- checked if true on isVisible return true -- visible if true)macroScript ProjectioModToggleNodeVisibilityenabledIn:#("max") category:~PROJECTIOMODTOGGLENODEVISIBILITY_CATEGORY~ internalCategory:"Projection Modifier" tooltip:~PROJECTIOMODTOGGLENODEVISIBILITY_TOOLTIP~ ButtonText:~PROJECTIOMODTOGGLENODEVISIBILITY_BUTTONTEXT~ ( On Execute Do ( Try ( if selection.Count > 0 do ( pmod = FindPMod $ if pmod != undefined do ( pmodi = pmod.projectionModOps pmodi.setGeomSelNodesVisibility (not pmodi.getGeomSelNodesVisibility()) ) ) ) Catch() ) on isEnabled do ( selection.Count > 0 ))macroScript ProjectioModDisplayToggleEnableenabledIn:#("max") category:~PROJECTIOMODDISPLAYTOGGLEENABLE_CATEGORY~ internalCategory:"Projection Modifier" tooltip:~PROJECTIOMODDISPLAYTOGGLEENABLE_TOOLTIP~ ButtonText:~PROJECTIOMODDISPLAYTOGGLEENABLE_BUTTONTEXT~ ( On Execute Do ( Try ( if selection.Count > 0 do ( local pmod = FindPMod $ if pmod != undefined do ( pmod.displayToggleEnable = (not pmod.displayToggleEnable) ) ) ) Catch() ) on isEnabled do ( selection.Count > 0 ))macroScript ProjectioModDisplayToggleModeenabledIn:#("max") category:~PROJECTIOMODDISPLAYTOGGLEMODE_CATEGORY~ internalCategory:"Projection Modifier" tooltip:~PROJECTIOMODDISPLAYTOGGLEMODE_TOOLTIP~ ButtonText:~PROJECTIOMODDISPLAYTOGGLEMODE_BUTTONTEXT~ ( On Execute Do ( Try ( if selection.Count > 0 do ( local pmod = FindPMod $ if pmod != undefined do ( local pmodMode = pmod.displayToggleMode if (pmodMode==1) then pmod.displayToggleMode = 2 else pmod.displayToggleMode = 1 ) ) ) Catch() ) on isEnabled do ( selection.Count > 0 ))
