Sphere Texturing
На сайте c 21.10.2013
Hi there,
How to texture a sphere in 3ds max like the attached picture ?
Thank you
На сайте c 23.10.2022
The simplest and most universal way to apply wood texture is the Planar UVW Map.
Many people like to complicate the unwrapping process so that the wood texture fits correctly and seamlessly. But everything ingenious is simple! This is how the unwrapping fits correctly and seamlessly. smiley-smile.gif
This method is not always applicable, but this method is applicable in most cases.
AlexHappy ©
Thank you.
Sometimes I use planar mapping but in this situation, it doesn't work.
Check the image below.
In this situation you need to use a different texture and Map Channel for problem areas.
Try using Advanced Wood material for turned shapes.
