Звуковухи: Realtek ALC889A vs Creative X-Fi Xtreme Audio
На сайте c 09.02.2007
РФ
Как и обещал, сравнил эти два источника звука:
Это чисто субъективное мнение - т.к. звуковые вкусы у меня свои, а слуха вроде как нет
Итак:
Заявленные характеристики Realtek ALC889A:
* High performance DACs with 108dB signal-to-noise ratio (A-weighting)
* High performance ADCs with 104dB signal-to-noise ratio (A-weighting).
* Meets Microsoft WLP3.10 and future WLP audio requirements
* Ten DAC channels support 16/20/24-bit PCM format for 7.1 sound playback, plus 2 channels of concurrent independent stereo sound output (multiple streaming) through the front panel output
* Three stereo ADCs support 16/20/24-bit PCM format, multiple stereo recording
* All DACs supports 44.1k/48k/88.2k/96k/176.4k/192kHz sample rate
* All ADCs supports 44.1k/48k/88.2k/96k/176.4k/192kHz sample rate
* Primary 16/20/24-bit SPDIF-OUT supports 32k/44.1k/48k/88.2k/96k/192kHz sample rate
* Secondary 16/20/24-bit SPDIF-OUT supports 32k/44.1k/48k/88.2k/96k/192kHz sample rate
* 16/20/24-bit SPDIF-IN supports 32k/44.1k/48k/96k/192kHz sample rate
* All analog jacks (port-A to port-G) are stereo input and output re-tasking
* Port-A/B/C/D/E/F built in headphone amplifiers
* Port-B/C/E/F with software selectable boost gain (+10/+20/+30dB) for analog microphone input
* High-quality analog differential CD input
* Supports external PCBEEP input and built-in digital BEEP generator
* Software selectable 2.5V/3.2V/4.0V VREFOUT
* Up to four channels of microphone array input are supported for AEC/BF applications
* Two jack detection pins each designed to detect up to 4 jacks
* Supports analog GPIO2 to be jack detection for CD input which is used as 9th analog port
* Supports legacy analog mixer architecture
* Up to 3 GPIOs (General Purpose Input and Output) for customized applications. GPIO0 and GPIO1 share pin with DMIC-CLK and DMIC-DATA.
* Supports mono and stereo digital microphone interface (pins shared with GPIO0 and GPIO1)
* Supports anti-pop mode when analog power AVDD is on and digital power is off.
* Content Protection for Full Rate loss-less DVD Audio, Blue-Ray DVD and HD-DVD audio content playback (with selected versions of WinDVD/PowerDVD)
* Hardware Zero-Detect output volume control
* 1dB per step output volume and input volume control
* Supports 3.3V digital core power, 1.5V or 3.3V digital I/O power for HD Audio link, and 5.0V analog power
* 48-pin LQFP ‘Green’ package
Заявленные характеристики Creative X-Fi Xtreme Audio
Technical Specifications
* Playback: 24-bit/96kHz 7.1
* Signal-to-Noise Ratio: >108dB (20kHz Low-pass filter, A-weighted)
* Total Harmonic Distortion + Noise at 1kHz: 0.006% (20kHz Low-pass filter)
* Recording: 24-bit/96kHz
X-Fi Technology
* X-Fi Crystalizer
* X-Fi CMSS-3D Virtual
* X-Fi CMSS-3D Headphone
Connectivity
* Speaker and Headphone connections for stereo to 7.1 (Line Out via three 3.5mm mini jacks)
* Line In / Microphone In / Digital Out* / Digital I/O** (shared 3.5mm FlexiJack)
* Auxiliary Line level Input (via 4-pin Molex connector)
* Intel HD Audio Compatible Front Panel Header (2x5pin)
* Digital Out supports SPDIF out and pass through of multichannel DVD sound
** Digital I/O requires Sound Blaster Digital I/O Module (sold separately)
Package Contents
* Sound Blaster X-Fi XtremeAudio sound card
* Quick Start Leaflet
* Installation CD
Теперь о совместимости X-Fi и Висты
Вопросы и ответы на официальном сайте Creative (почему не работают некоторые "вкусные" функции в висте)
Why is SPDIF passthrough not working with Windows Vista 64-bit? Will it ever?
SPDIF passthrough is available in the latest X-Fi update. For the Audigy Series, we cannot support this feature in Windows Vista 64-bit.
Will decoding of Dolby Digital and DTS signals be supported in the future? If not, why not?
These functions are not supported at driver level in Windows Vista and going forward will be supported at application level by applications such as Power DVD or WinDVD.
Will DVD-Audio be supported in the future?
We are not supporting DVD-Audio in Windows Vista.
Will 6.1 speaker mode be available in future drivers? If not, is this because of Creative or Microsoft?
No, as Windows Vista does not support this speaker configuration.
Теперь субъективная часть:
Драйверы с диска идущего с карточкой в Висте подглючивали... не было доступно управление громкостью по каждому каналу.
Обрадовавщись что есть программа обновления... запустил её... 120 мегабайтов скачались, но посреди установки программа вылетела...
На панелки настроек появились "вкусности":ДТС, ТаШИкс и др. Но все остальные настройки отказались работать.
Пришлось вручную качать последние дравера под звуковую карточку с оффсайта... но днем это оказалось не возможным, т.к. даже сам сайт открывался с трудом. Ночью всё закачалось, установилось без проблем, все настройки стали доступны, но что исчезло:
*Вкусности типа поддержки ДТС, Долби и т.д.
*Выбор дескритизации вывода 48-96/16-24
*Поддержка хардварного 3Д звука для игр - только через дополнительную программу.
И всё это из-за Висты 64-битной.... - о чем и говорилось на сайте.
Из того что не понравилось еще:
*Нет возможности сделать самостоятельный набор колонок отличный от 2.0, 4.0, 5.1, 7.1 (по выводу 1:1)
*Давно уже на многих встроенных кодеках и на одной из моих старых звуковых карточек(старее X-Fi) были разъемы с определителем - вставлено туда чегонить или нет.
Из сравнения по звучанию (при поднятии частоты дескритизации и битности встроенного кодека ALC889A до 192кГц/24бит):
качество звука было примерно одинакого, тонкости были слышны и там и там, разные АЧХ. На качественных источниках звук и там и там был примерно одинаковым, на источниках 44кГц/16бит у X-Fi звук оказался более "мягким" и более "правдивым".
Ещё одним минусом оказался переодический треск в левой колонке.
(Ещё X-Fi хорошо греется)
Итог: Вытащил X-Fi из компьютера
Не смотря на сравнительно хороший звук (и даже если бы отсутствовал треск в колонке), непонравилась поддержка со стороны производителей - выйдет виндоус 7 в ней Креатив отключит ещё несколько функций; Видимость кучи настроек, по сути настраивать там ничего не дают;Все проблемы драйверов решили программами-заплатками - либо отключкой функций.
Напоминаю: это моё субъективное мнение.
PS В ходе проверок выбыл WinAmp - на качественных источниках было заметно искажение.
PPS Всё делалось на слух на имеющихся колонках. Более профессиональные обзоры и тесты можно найти например здесь:
(ALC889A)http://www.ixbt.com/mainboard/gigabyte/rmaa/ma790fx-dq6-alc889a.htm
(X-Fi)http://www.ixbt.com/multimedia/creative-x-fi.shtml
Обсуждение здесь:
(ALC889A)http://forum.ixbt.com/topic.cgi?id=12  :46251
(X-Fi)http://forum.ixbt.com/topic.cgi?id=12  :44621
На сайте c 29.05.2009
Di_2
Согласен с тобой x-fi, по крайней мере такой - лажа ( у самого был такой). Под современными операционками звук на хорошего встроенного кодека ничем не хуже дешевых версий x-fi (плюс отсутствие Creativовских косяков).
ИМХО если нужен действительно качественный звук,берите лучше ESI Juli@ или ASUS Xonar.
РФ
Ну вот и на IXBT произвели сравнение этих двух звуковух (ну ещё добавли E-MU 1212M):
http://www.ixbt.com/multimedia/creative-x-fi-pcie.shtml
На сайте c 09.01.2009
Спрошу тут по звуку, если никто не возржает.
Ситуация такая: у меня есть старый комп, на который я давно ставил звуковую карту Creative Sound Blaster Live 5.1 и записывался на ней очень даже здорово (я иногда занимаюсь музыкой и оцифровываю ее потом для потомков ), потом я купил новый компьютер со стандартной картрой (или отсутствием ее), на днях решил взять ту и поставить сюда. Новый комп ее как бы даже и увидел, т.к. начал искать драйвера, но тут выскочило окно, с напоминанием, что я, возможно стал жертвой подделки (это они про Windows 7), ну и обновление, соответственно не проходит. Ну да Бог с ним, снял я эту карту, но теперь при пользовании аналоговым входом - я через розовый разъем для микрофона подключаю гитару и синтезатор, звук почему-то идет с запозданием на полсекунды. Что это может быть?
А еще, правда я не знаю, связано ли это с "внедрением" звуковухи, уровень записи какой-то сумасшедший и совсем не правильный.
Заранее, премного благодарен.
На сайте c 29.11.2008
Belarus
Профессор, могу лишь предположить, что запоздания вызваны тем, что не работает протокол ASIO. Есть такая прожка маленькая: ASIO for All называется, с некоторой долей вероятности может помочь улучшить время задержки.
P.S. розовый разъем для микрофона - это не аналоговый, а линейный вход. Насколько помню, Sound Blaster Live никогда не имели аналоговых входов
toxism, спасибо, доберусь до дома, попробую эту ASIO.
А насчет розового входа - это я так выразился, просто в Sound Blaster есть еще и вход для миди-клавиатуры (может еще для чего), я ее по большей части из-за этого и брал, он такой, навроде разьема под монитор, а остальные - просто дырочки, вот я и назвал их аналоговыми, так-то конечно линейный
Belarus
для миди-клавы выглядит как старые такие пяти-пиновые круглые... но я миди-клаву по USB подключаю, поэтому не парюсь, а миди-шнуром только в студии меня коннектят.
