Цитата x-ender:
ага, точно обновили, потому что прям с полгода назад она тупая да нельзя была, ну погоду спросить, а щас прям раздупляет всё))
Упс, какой интересный момент проявился=))))) задал я тест алисе
Вот промпт "Create a single-file browser project called "Underwater Observation Pod Explorer". The page should show a stylized 3D first-person scene inside a small underwater observation pod. The user should be able to move around inside the pod and look around freely. Requirements: Use Three.js. Everything must be in one index.html file. The project should run immediately in a modern browser. Camera and movement: Use a first-person viewpoint. Allow the user to move only inside the pod interior. Movement should support desktop and touch devices. Desktop controls: - WASD or arrow keys to move, - mouse drag or pointer look to look around. Touch controls: - on-screen joystick or directional pad for movement, - on-screen look control or touch drag for looking around. Add visible on-screen controls for touch that stay compact and readable. Movement should include collision handling. The camera should not pass through walls, windows, consoles, seats, lockers, pipes, or other large objects. The player should stay within the room and feel grounded at a believable eye height. Scene: The pod should be a small walkable underwater observation room with a clear interior layout. The interior should include: - curved glass viewing windows, - a metal floor, - wall or ceiling pipes, - cables, - control consoles, - blinking screens, - gauges, - warning lights, - storage lockers, - seats, - railings or structural supports, - a hatch or door area, - and several small props that make the room feel believable. Outside the pod there should be a rich underwater world with: - rocks, - coral, - sea plants, - schools of fish, - floating particles, - bubbles, - and at least one larger distant creature or a passing submarine. The underwater environment should be visible in multiple directions, not only in front of the user. The outside world should feel deep and layered, with clear foreground, midground, and background. Atmosphere and animation: Add underwater fog. Add light rays filtering through water. Add caustic light patterns. Add soft reflections or highlights on the glass. Add subtle animation in sea plants, fish, particles, bubbles, and distant creatures. The pod interior should also feel alive: - small screen animations, - blinking lights, - subtle ambient motion, - slight changes in light from the water outside. Visual quality: The interior should feel dense, polished, and rewarding to inspect while moving around. The exterior should feel immersive and visually rich. Objects should be grounded and placed with believable scale. The scene should feel like one coherent underwater environment rather than separate disconnected decorations. UI: Add a compact UI with: - Reset, - Pause, - Quality. The UI should stay small and should not cover the main view. Evaluation focus: Focus on visual atmosphere, depth, composition, lighting, believable first-person exploration, readable touch controls, and reliable collision-based movement inside the pod." вот результат Алисы=))) На первый взгляд для такой нейронки даже и не плохо...
Но......вот это же задание выполнил дипсик=))))
Гыыыыы..... Спрашиваю Алису, как так то? а она вот что пишет
Ну и для сравнения Квин выдал такой результат:
Еще там есть звук сонаров, пару экранов работающих(Радар и внешняя камера рыб снимает)...
ЗЫ. Заставил переделать, вначале она попыталась втереть дичь
вот результат
________________________________________________________________________________
__________________________________________РАЗДЕЛИТЕЛЬ__________________________
__________________________________РАЗДЕЛИТЕЛЬ__________________________________
https://github.com/RoutineMiku/apkstart/releases/tag/v0.5.0-fix
Китайцы дропнули гениальную APKStart, которая скрывает эмуляторы от ваших глаз и делает всё интуитивно понятным.
По факту, это первая подобная программа с таким уровнем удобства. Никакие BlueStacks даже близко не идут в сравнение.
По клику на APK вы получаете ярлыки с родными иконками приложений — сразу на рабочий стол и в меню Пуск.
Прога легко открывает приложения в окне или на фуллскрин и запоминает ваш выбор.
Внутри — Android 14 с Google Play, то есть работать будут даже приложения, завязанные на сервисах от Гугла.
Запускает всё за пару секунд и синхронизирует файл между Windows и Android.
Совместим с Windows 10 и Windows 11.
Если кто-то хотел стереть границу между смартом и пека велкам=)
А еще учитывая, что у нас есть теперь всякие ИИ под боком, может что-то прикольное выйти...а может и нет.
