Copy DVD to ISO with Best DVD to ISO Burner
На сайте c 16.03.2017
Do you want to create an ISO image file from a DVD disc? Or, need to get a DVD ISO backup of your precious DVD disc onto computer hard drive so you could preserve your DVD content safely in case the original DVD disc is damaged or lost? If you have such DVD to ISO copy need, you’ll get satisfied solutions here.
An ISO file, often known as ISO image file, is a single image of an optical disc of CD, DVD and Blu-ray. As optical disc image file, ISO image file includes entire content of source disc. While discs are fragile and not convenient for long-term safekeeping, ISO image files help save disc content in a safer way. Read the content below to learn how to copy DVD to ISO image file and other ISO related solutions.
Best Copy DVD to ISO Software
The best DVD to ISO copy software should get these features: bypass encrypted DVD discs, support both DVD disc to ISO image file backup and ISO to DVD disc backup, copy DVD to ISO without any quality loss, easy to use and available in both Windows and Mac. Of course, the price is also an important element.
Free DVD ISO Maker is wonderful, but not the best DVD to ISO burner to burn DVD to ISO image file since it firstly doesn’t support video DVD, and secondly it is not available in Mac. Therefore, Leawo DVD Copy is the best DVD to ISO copy software to help you easily copy, burn and rip DVD to ISO image file.
Leawo DVD Copy – The ever best DVD to ISO backup software for PC/Mac users to rip, copy and burn DVD disc to ISO image file on PC or Mac computer in only a few simple clicks.
* Copy DVD to ISO image file without any quality loss;
* Copy and burn ISO image file to DVD disc in clicks;
* Bypass any DVD disc protection and region code restriction;
* Easy to use interface for both novices and veteran;
Why is Leawo DVD Copy the best DVD to ISO copy software
1. Decrypt any protected DVD disc and remove region code for DVD to ISO copy.
2. 1:1 disc to disc duplication. Copy DVD to ISO image file without quality loss.
3. Copy and burn ISO image file to DVD disc in one click.
4. Extremely easy to use interface for both novices and veteran.
How to Burn DVD to ISO with Leawo DVD Copy
To copy DVD to ISO image file with Leawo DVD Copy, you need to firstly get these things prepared:
1. Source DVD disc (DVD movie folder is also supported by Leawo DVD Copy for DVD folder to ISO copy);
2. Computer with DVD disc recorder drive and enough hard drive storage;
3. Internet connection.
Then, you need to download and install Leawo DVD Copy on your computer via the download links provided above. The Windows version of Leawo DVD Copy could run on Windows Vista and later, while Leawo DVD Copy for Mac runs on Mac OS X 10.6 and later. Download and set it up according to your computer system. Follow the below steps to learn how to copy DVD to ISO with Leawo DVD Copy (both Windows and Mac versions share the same interface and DVD to ISO copy operation).
Step 1: Add source DVD moviesInsert DVD disc into the drive and then launch Leawo DVD Copy. Click the “Add Blu-ray/DVD” button to import source DVD movies from disc drive. If you want to copy DVD folder to ISO image file, choose source DVD folder from your computer to drag and drop into this program.
Step 2: Set DVD copy modeClick the drop-down box at the bottom left corner and then select a target DVD disc type (DVD-9 or DVD-5) to set as ISO image file dsic type for future ISO to disc burning. After that, select a copy mode from Full Movie, Main Movie and Custom Mode. If you want 1:1 disc duplication, just select “Full Movie” mode.
Step 3: DVD backup settingsClick the big green “Copy” button. Since you need to copy DVD to ISO, choose “ISO File” option under “Copy to” to burn DVD to ISO image file. Set an directory in “Save to” option to save output ISO image file. Customize “Disc Label” if you like.
Step 4: Start copying DVD to ISO image fileClick “Copy” button to start copying DVD to ISO image file with Leawo DVD Copy.
Congratulations on connecting to the Internet. The DVD died.
не читал, но осуждаю
