Corona Show VFB
На сайте c 13.10.2015
Не могу назначить быструю клавишу для "Corona Show VFB" . В списке " Configure user interface " отсутствует , есть только для стандартной и для Vray . 3ds max 2016 sp4 / Corona 5 ( hotfix 2)
На сайте c 04.09.2016
You must select the Corona category. Then you can define a shortcut
This list doesn't appears in my corona section , i suppose it is due to my corona version , or anything else
Цитата elmar55592:
This list doesn't appear in my corona section, i suppose it is due to my corona version, or anything else
Maybe that's why.
But if your rendering engine is on the corona, pressing the f9 key will also make the vfb corona appear
