Hello to all of you! I would ask for a little help.. I’ve tried everything. I’m having problem with this white line, it appears in the joints of the white furnitures. I’ve tried to increase the subd. and played with the material, with the GI.. If you can help me, I’ll be grateful! Thank you!
Thank you guys...but none of this worked :( and I'm switching from presets to presets and I think i've tried everything :( don't have any ideas anymore..
What is the scale of the scene? all made real size?
Maybe some light object intersects geometry of the scene?
I've checked all the lights.. none of them intersects any geometry.. thank you for the suggestion! I will keep trying..
walls have a thickness?
Yes.. the walls have thickness. All made real size. I've done so much scenes and renders.. this is happening for the first time. I've tried to remove the sun and to use another source of light.. dome light. Happened again. I've tried to modify the furnitures.. Happened again..I suppose it's from the settings.. What next?
Well then there is one solution left, to send the scene and we'll see.
