на работе стоит 3d max 2013 design. По многим причинам нужно дополнительно установить 3d 2010, при начале установки выдает окошко
![image.jpg](http://s9.postimage.org/z94tf8zqz/image.jpg)
может у кого есть идеи? гугл не помог
2013/1/17:12:38:07 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:12:38:10 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:12:38:17 admin ADMIN-ПК === Setup ended ===
2013/1/17:12:52:30 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/17:12:52:37 admin ADMIN-ПК === Setup ended ===
2013/1/17:12:53:40 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:12:53:42 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:12:53:49 admin ADMIN-ПК === Setup ended ===
2013/1/17:12:54:49 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/17:12:57:22 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/17:13:35:30 admin ADMIN-ПК === Setup ended ===
2013/1/17:13:35:52 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:13:35:53 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:13:35:55 admin ADMIN-ПК === Setup ended ===
2013/1/17:13:37:10 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/17:13:37:14 admin ADMIN-ПК === Setup ended ===
2013/1/17:13:37:30 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:13:37:33 admin ADMIN-ПК === Setup ended ===
2013/1/17:13:39:17 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/17:13:39:57 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/17:13:40:03 admin ADMIN-ПК === Setup ended ===
2013/1/17:13:43:58 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:13:43:59 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/17:13:44:04 admin ADMIN-ПК === Setup ended ===
2013/1/17:13:44:44 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/17:13:44:47 admin ADMIN-ПК === Setup ended ===
2013/1/23:12:13:28 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/23:12:13:31 admin ADMIN-ПК === Setup ended ===
2013/1/23:12:15:35 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/23:12:16:50 admin ADMIN-ПК === Setup ended ===
2013/1/23:12:17:20 admin ADMIN-ПК === Setup started on ADMIN-ПК by admin ===
2013/1/23:12:17:23 admin ADMIN-ПК === Setup ended ===
2013/1/23:12:19:15 admin ADMIN-ПК Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2013/1/23:12:27:50 admin ADMIN-ПК === Setup ended ===
