3.50.01 - Beta release
На сайте c 26.10.2006
3.50.01Beta
releaseDate – November 22, 2016
New Features:
V-Ray
Enable usage as an interactive production renderer (IPR)
Enable the resuming of bucket renders from raw .vrimg files
Enable the resuming of progressive rendersExperimental implementation of adaptive lights
Optimize GI rendering
V-Ray RT
Support for direct output to Oculus Rift and HTC Vive
Object picking in VFB
Enable Set focus distance in the VFB for the selected camer
V-Ray GPU
Aerial Perspective support
Support for matte materials shadow catcher
Support for the VRayStochasticFlakesMtl material
Initial implementation for on-demand mip-map texture in production rendering mode
Less CPU memory usage when rendering scenes with many textures
Less GPU memory usage when rendering scenes with many textures
Implement support for Render mask
Support for velocity render element
Better handling of geometry and materials updates during ActiveShade
Add Low GPU thread priority option
Support for additive mode of the VRayBlendMtl
Support for transparency for the layers of the VRayBlendMtl
Add support for VRayAtmosphere render element
Fixed differences in lighting between V-Ray RT CPU and GPU
Fixed differences in texture blending between V-Ray RT CPU and GPU
Support for Irradiance Map from file
Support for RenderID, ObjectID and MtlID render elements
Implement ground projection of VRayHDR
VFB
Implement hardware acceleration support for lens effects
VRay
MtlImplement Glossy Fresnel option
VRayMtl
VRayALSurfaceMtl
Include alSurface shader port for V-Ray in the installation
VRayProxy
Support for user property tags in the proxy file name
VRayScannedMtl
Add ability to capture and render the back lighting
VRayVolumeGrid
Add a render preset for Maya Fluids vdb
Support for Cap Mesh mode in V-Ray RT
остальное тут:
https://docs.chaosgroup.com/display/VRAYMAXBETA/3.50.01
https://labs.chaosgroup.com/index.php/rendering-rd/understanding-resumable-rendering/
А вот с остановкой рендера и последующим запуском с момента остановки это хорошая фишка. Те кто верил в кнопку паузы в старых версиях ВиРея, так вот дождались :)
Смотрю и РТ ковыряют, глядишь в 4-5 ВиРее можно будет переходить и рендерить, как в короне.
http://dabarti.com/vfx/procedural-bump-in-v-ray-gpu-rt-3-5/
Вот ещё вроде недурно!
Лет пять назад было бы недурно, но сейчас всякие Substance Painter/Designer задрали планку настолько высоко, что до них уже не дотянуться.
На сайте c 23.01.2016
Россия, ЦФО
Лучше б аналог лайтмиксера прикрутили. Возобновляемый рендер на Короне давно уж.
Аналог лайтмиксера в вирее есть, только надо PDplayer во вторую руку брать. И ещё есть какой-то скрипт сто лет назад написаный, которым никто не пользуется.
очень интересно как с помощью PDPlayer (у меня он есть) можно крутить свет? ткните носом пожалуйста)))
На сайте c 28.11.2007
https://www.chaosgroup.com/pdplayer
https://www.youtube.com/watch?v=VQISe90BzHg
Да, есть разные видосы, можно найти.
https://www.youtube.com/watch?v=2F4NlqPLbP4
На сайте c 27.07.2009
RU
как они умудрились сделать это так неудобно и просто отвратно даже визуально?
достаточно фотошопа, но все же в Coron, бесспорно удобнее реализованнhttps://www.youtube.com/watch?v=dsNUdQh1HkA
Да они староверы )) PD player ещё и отдельной прогой. Грузить в него, крутить там...
На сайте c 08.03.2010
Красноярск
На сайте c 04.02.2015
Пустячок, а приятно. Но уже даже привычно стало "ставить на паузу", выставив в настройках рендера "сверху-вниз" или "слева-направа", ну и дальше сохраняя и вызывая ранее сохранённый .vrimg. По сути - та же пауза, но только с некоторым шаманством)))
Я вот только не понял вот этого:
* Support for Irradiance Map from file
* Support for RenderID, ObjectID and MtlID render elements
* Add support for VRayAtmosphere render element
Вроде и на 3.0, и на 2.4 (может и того раньше, уже не помню) это всё было, не? Или тут что-то другое имеется в виду?
Красноярск
Цитата bp-alex-007:
Я вот только не понял вот этого: * Support for Irradiance Map from file * Support for RenderID, ObjectID and MtlID render elements * Add support for VRayAtmosphere render element Вроде и на 3.0, и на 2.4 (может и того раньше, уже не помню) это всё было, не? Или тут что-то другое имеется в виду?
речь идет о V-Ray RT
На сайте c 11.10.2009
Ростов-на-Дону
Наконец то на GPU прикрутили то чего так не хватало. Просто отличное обновление для GPU
На сайте c 16.07.2010
Такие вкусные рендеры в примерах, аж не верится. Я 5 лет мучался с этим виреем, кучу дней и ночей тратил на тестирование каждой настройки, причем с каждой новой версией функционал этих настроек постоянно менялся, и приходилось заново тестировать. Делаю интерьер, в голове вижу красивую, финальную картинку, рендерю, и получаю результат на 30-50% хуже того, чего ожидал. Потом приходится в фотошопе вытягивать. Под конец вроде уже неплохо стало получаться, но время рендера, если не фейковать, возростало в разы. Поэтому вот последние 8 месяцев не работаю в нем. Иногда скучаю по вирею, руки чешутся, хочется снова в нем покопаться, протестировать. P.S. Возможно, у меня руки не с того места)
Это всё - синтетические прибабахи, то же самое делается с использованием тех же каналов лайт селекта в фотошопе и в гораздо более тонком виде. Синтетика этого решения в том, что подкручиваемая интенсивность света не влияет на GI. Да, это очень удобно для постпрода, но ожидать физически корректного результата от таких танцев не стоит. Таким образом, правдоподобно полностью включать-выключать ИС - не выйдет, равно как и сделать из дневного сценария ночной (и наоборот).
Ну тогда сейчас самое время вернуться))) С версии 3.3. вирка стала просто элементарно настраиваться (на автосабдивах, без использования сабдивов ИС и матов) - тут и мартышка справится! Ну а если за спиной - багаж из тонкой настройки предыдущих версий, то не работа будет, а просто одно удовольствие). Плюс к тому очень ощутимо сократилось время рендера, ну а если приноровиться с умом пользовать денойзер (это уже с версии 3.4, по-моему), то время высококачественного рендера можно сократить просто в РАЗЫ!
На сайте c 27.07.2016
Красноярск
как бы от вирэя вообще не стоит ожидать физически корректного рендера в целом
Цитата bp-alex-007:
Ну тогда сейчас самое время вернуться))) С версии 3.3. вирка стала просто элементарно настраиваться (на автосабдивах, без использования сабдивов ИС и матов) Плюс к тому очень ощутимо сократилось время рендера, ну а если приноровиться с умом пользовать денойзер, то время высококачественного рендера можно сократить просто в РАЗЫ!
Врятле этим вы переманите с короны людей ) Всё это уже давно есть в короне. Но как апдэйт (говорю о 3.5Beta) для вирэйщиков конечно не плохая добавка )
Я даже больше скажу: у меня и задача-то такая не стоит))) Посмотрев демку новой сборки короны и задолбавшись переделывать материалы из-за чрезмерно расплодившихся в последнее время на 3ddd моделей под корону (конвертер из короны в вирку работает ведь только с установленной короной), решил и сам её освоить, когда время будет.
Насколько я понимаю, для визуализатора интерьеров у короны перед виркой есть только один существенный недостаток: скорость рендера (благо, с удобством настройки вирка сделала гигантский прыжок вперёд). Тем не менее, в короне очень много приятных плюшек всё для тех же интерьерщиков, поэтому она становится практически "маст хэв" в качестве второго рендера. Может, когда они так же далеко продвинутся в среде софта для аниматоров и разработчиков визуальных эффектов, вирке вообще будет нечего кушать)))) Но пока корона только очень успешно откусила серьёзный кусок у вирки в сегменте архитектурной визуализации.
Ну это как я себе представляю, во всяком случае...
