3DS Max 2019
На сайте c 16.03.2010
Ну что ж вот и он нечетный!
Autodesk has made the documentation for its upcoming release available online. The “What’s New?” section for 3DS Max 2019 points towards several new features, including:
    • A new OSL Map and built-in support for Open Shading Language including the ability for users to use existing shaders or author their own OSL maps.
    • A new Shape Booleans tool that enables users to use boolean operations on splines. It uses the same UI as the recently updated mesh booleans features.
    • A new advanced procedural map for creating wood textures with outputs that support a PBR workflow.
    • A new Shared Views feature that enables artists to publish a model or a selection online directly from within 3DS Max. Could be used for communicating with collaborators and receiving feedback.
    • Improvements to Alembic support to make it possible to preserve more data channels when transferring animated or static data between DCC tools.
    • Improvements to extruding and bevelling workflows so that the normals are now respected when multiple faces with shared edges are at different angles. If you prefer the previous behaviour there’s a new extrude angle parameter to switch between the new and legacy behaviour.
    • The Renderable Spline modifier has been updated with the ability to correct twists plus the ability to quad cap and round the ends of open splines.
    • New options for project folders so that users can create new folder hierarchies based on recent projects, use the default structure, or create an empty project with no existing structure or hierarchies.
    • To improve security executable code and MAXScript files have been signed with digital signatures.
    • New features in 3DS Max Interactive (a separate download) including the ability to edit your levels in virtual reality, a new smart placement tool that works in both the viewport and VR, live linking of transforms between 3DS Max and 3DS Max Interactive, the ability to convert 3DS Max’s photometric lights to Physical lights in interactive including IES files, and a new template compatible with Oculus and HTC Vive systems.
  It’s important to mention that 3DS Max 2019 has yet to be officially announced, we’ll update this news post as more information becomes available. See the current list of new features on Autodesk’s Documentation site.
мой канал в телеграме: telegram channel cgnews
На сайте c 09.01.2014
И всё?
Цитата Kenzo80:
И всё?
А я смотрю у них тема появилась в апдейты не ошибки чинить, а функционал расширять. 2018 и 2018.4 это две большие разницы. Возможно с 2019-ым аналогично будет.
На сайте c 07.06.2009
мда.. форум ломится у них от запросов на введение нужных фишек, о которых просят юзвери уже не первый год.
а они все какие-то мелочи добавляют.
интересно, иконки в интерфейсе в этой версии опять поменяют?)
Цитата Kenzo80:
И всё?
а вообще, да, судя вот по тому что пишут на cgchannel с 2018 макса автодески перешли на новую модель выпуска, где с каждой обновой они не только ошибки правят, но и новые фишки внедряют.
"However, it’s worth bearing in mind that with the 3ds Max 2018 release cycle, Autodesk rolled out functionality steadily across four quarterly updates rather than concentrating everything in the initial release." http://www.cgchannel.com/2018/03/autodesk-unveils-3ds-max-2019/  )
На сайте c 04.06.2015
Днепр, Киев
думаю процедурка дерева будет на столько же "полезна" как и процедурка мрамора
ну,пару раз лет за 10 я процедурку мрамора использовал)
На сайте c 06.08.2013
А шо там на видео? А то ошибку выдаёт.
На сайте c 22.12.2009
Город, близ которого греки впервые разгромили персов
Цитата Kenzo80:
И всё?
нет не всё, название тоже изменилось))Был Autodesk 3dsmax 2018, а стал  Autodesk 3dsmax 2019smiley-smile.gif
Kenzo80, видос про osl, линк оставил.
На сайте c 12.05.2008
Эх, я сегодня только Макс 2018 поставил посмотреть, потыкать в новый интерфейс. После 16го непривычно.
Кстати, оффтоп конечно, но где взять апдейты на 2018? а точнее 4й апдейт. 3й на персии был, а вот на сайде Автостола для 2018 нет нифига.
О, сорян, все нашел в теме про 2018.
На сайте c 13.07.2010
автодеск апп ставьте, выполните вход в аккаунт автодеска и будут все последние обновы, в том числе которых на сайте еще нет.
falik
Ставил (ну он с максом встал) и входил в аккаунт. На автокад нашел апдейт, на Рекап нашел (на пятый апдейт я его удалил))) )
На макс не хотел находить, на себя (приложение Автодеск) не находил.
Не исключаю некоторую тупость моего инета конечно (4г от мегафона)
На сайте c 21.09.2009
Итак, кому не терпится опробовать новый 3ds Max 2019 https://t.me/cgnews  тут все есть)))
Также уже можно скачать Corona render с поддержкой 3dsMax 2019 Corona Renderer 1.7 for 3ds Max (Hotfix 4)
Тут нельзя постить ссылки официально не выложенного продукта на сайте Autodesk. Администрацией 3DDD это расценивается как ВАРЕЗ!!!
На сайте c 09.01.2008
Bestviz
Помимо ссылок вы оставили ключи продуктов.
На сайте c 06.06.2016
3ds Max 2019. Что нового. Часть 1.(RU)
Смотреть на YouTube
автор: Boris Kulagin
На сайте c 13.07.2009
Цитата CrAsssH:
Bestviz
А ключи продуктов разве не в открытом доступе?
На сайте c 31.01.2008
Chelyabinsk
Вроде не валится и фишки новые понравились. Но некоторые старые баги остались =\Поскорее бы обновили все народные плаги и можно перелазить))
Читают эту тему: Borka82 , st.kontur
