seventy в шапке есть ссылка на производителя, спроси у них.
________________________________________________
24.03.2020
Появилась новая Alfa 5 версия. Ссылку добавил в шапку.
Обновления исправления улучшения:
Added
ARCHICAD 23 support
Reset plugin window UI for a newly created project
Added new denoising modes - Intel CPU and Nvidia GPU ( during interactive rendering )
Added UVW randomizer texture
Added resume rendering functionality. Both Resume last and Resume from file are working as expected
Added Clear VFB between renders switch
Added rotation and color temperature options into Corona light
Changed
Geometgry parsing
Updated denoising tooltips
Fixed
Sun in Light Select render element is now working
Fixed refreshing of the Corona plugin window UI with saved properties of the current project
Fixed material issues when material properties changes were not propagated to the scene during the Interactive rendering session. This will fix also HDRI sky texture Z rotation, etc..
Fixed not fully working denoisingFixed denoising functionality in VFB window
Fixed FOV change in two-points perspective renders
Fixed Enable/Disable functionality for render regions
Fixed Enable/Disable of rendering related buttons on the plugin panels
Fixed installer will now properly install Corona Image EditorMinor UI tweaks
Core
Updated to the core version 5
