filatkin_m,
You can put the following into the string options rollout (you'll need to enable the devel settings for this Render Setup -> System -> System Settings -> Enable devel/debug mode)
int progressive.boxScramblingPassLimit = 100
The number should be higher than your pass limit, as this is the amount of passes where Corona will start to use buckets. Let me know how this works for you.
