уже когда то выкладывал его,там и сабы можно регулировать и интерполяции и всего и всякого. раньше юзал
-- The VRay Automator, (C) by Metin Seven - www.sevensheaven.nl
-- A simple MAXScript to automate otherwise tedious, repetitive,
-- time-consuming, sleep-inducing tasks regarding VRay.
-- This script is free for any use except for profit by selling it.
-- If you want to distribute this script in any way, please contact
-- the author: metin@sevensheaven.nl
-- Installation instructions:
-- 1: Copy the script into the UI/MacroScripts folder of your 3ds Max root folder.
-- 2: Startup Max.
-- 3: In the Customize dialog, go to the "SevensHeaven" category.
-- 4: Drag the VRay Automator into any desired toolbar or put it in a quad menu.
-- 5: Use this valuable tool forever and ever and ever.
-- Note: change the default values/types to your favourite values/types
-- (it's the last of the three values in the various spinner range values).
-- I'll elucidate my default settings:
-- Glossiness: 1,0 - Because I guess that's the most used value and it renders fast.
-- Subdivisions: 15 - Because the default of 50 is too high and causes unnecessary slow renders if you don't use
-- interpolation. Subdivision values lower than 15 gradually start showing noisiness.
-- Maximum Depth: 10 - Because the default of 5 is too low, causing less realistic reflections and refractions.
-- Index: 1.52 - Because I think 1,6 is just a little bit too refractive for standard glass.
-- BRDF type: Ward - Because it's the shader that looks best.
-- The high quality default interpolation values are for compensating the loss of detail that interpolation tends
-- to cause when using low quality values.
-- Light Multiplier: 30 - Simply the default.
-- Light Sampling Subdivs: 12 - because the default of 10 often looks just a little bit too grainy.
-- Planned for the next release:
-- * Support for VRay 1.5 functions.(2.0 vray тоже работает)
