Не запускается 3Ds Max 2020
На сайте c 01.11.2012
Помогите пожалюста 3d max 2020 просто престал запускатса запускаеш появется логотип и через 5-6 секунд ишезнит и все скажите в чем проблема как решит ?
На сайте c 21.09.2009
какие плаги или скрипты ставил перед этим?было такое на какой то версии Fstorm, и какойто скрипт по чистке тож такое делал, проверяй
RUSTTM
как проверята ?
Slazzo а где логи хранятса?
2019-08-22 10:43:09.200 [O] Created AdClmHub Logger level [error]
вот чо пишет ЛОГИ
2019-08-23 19:37:37.534 [O] Created AdlSdk Logger level [error], API version [2.4.3.23]2019-08-23 19:37:37.534 [E] Invalid log level was specified by environment variable ADLSDK_LOG_LEVEL[]; fall back to the default [error].2019-08-23 19:37:37.541 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:37.741 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:37.942 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:38.144 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:38.344 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:38.545 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:38.745 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:38.946 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:39.146 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:39.346 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:39.546 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:39.746 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:39.946 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:40.146 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:40.346 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:40.546 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:40.746 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:40.946 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:41.146 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:41.346 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:41.546 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:41.746 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:41.946 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:42.146 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:42.346 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:42.546 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:42.746 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:42.947 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:43.147 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:43.347 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:43.547 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:43.748 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:43.948 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:44.148 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:44.348 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:44.549 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:44.749 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:44.949 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:45.149 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:45.349 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:45.550 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:45.750 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:45.950 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:46.151 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:46.351 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:46.551 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:46.752 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]2019-08-23 19:37:46.952 [E] CAdlsAdapter::GetServiceAddress(): failed to parse JSON [ ]
На сайте c 17.09.2012
Папка пользователя находится по адресу c:\Documents and Settings\User\Local Settings\Application Data\Autodesk\3dsmax\2014 - 64bit\ENU\удали эту папку. все настройки макса собьются до стандартных.
yjinbs удалил без резултатно
преустановка не помогло
блин преустановис систему преустановил макс и на 3 тй дкень бадс тоже самое престал запускатса smiley-bomb.gifsmiley-shout.gif
что делать????????????
На сайте c 31.07.2014
Barcelona
Могу чуть добавить, столкнулся с той же проблемой, возникла она после отключения электричества в доме. Решения пока нет)
тоже эту фигню словил, единственно что помогло это откат точки восстановления за день до того как заметил эту проблему, а что делал с системой так это установил ориджен и апекс игру, не понятно как игра могла сломать макс, хотя там тоже были проблемы с установкой
На сайте c 26.07.2008
Так чего, народ, опасно 2020 ставить? Есть еще такая статистика? 2014-2018 у меня годами работает...
Uraken
Пока не ясно, я на нем с пару месяцев наверное сижу, фишки в нем есть прикольные апдейт 2 поставил, но вот у моей знакомой тоже вдруг перестал запускаться, переустановка ничего не помогает она винду переставляла. Как у меня было я выше описал.
На сайте c 04.03.2015
сборка винды какая ? на 1703 все норм
На сайте c 09.01.2014
Цитата Plutonium:
1703
Старьё.
Цитата Kenzo80:
Цитата Plutonium:
1703
Старьё.
увы
На сайте c 16.03.2016
у меня 1806, у подруги 1903собственно попробовал еще раз поставить ориджен после отката системы, пока все работает, какая то мистика творится, причем тут вообще джаваскрипты, напихали какого то мусора в программу.
И да первые две строки с ошибкой не влияют на запуск. то есть с ними запускается,макс не работает когда появляется это в логе. и странно что в интернете нет ничего по этой строке
На сайте c 16.05.2014
St. Petersburg
Я конечно всё понимаю, но в от этого я уже не понимаю... Та же херня, лого, 5 секунд, дальше падает из списка задач. Всё что выше пробовал, одна херня... Макс заболел видимо и сильно... (версия 2020, без апдейтов). Заказы горят вопрос срочный.
St. Petersburg
Ез, пробовали и это в том числе(
На сайте c 16.10.2006
Мде, у меня сегодня на работе на Win10 Home после запуска Макса 2020 - выдал сообщение что софт то  нелицензионный - типо решайте вопрос - сносил лицензию - не помогло. Дома всё ровно.
D-d_Man т.е. лицушный макс в офисе выдал, что он не лицушный нифига? О_о
St. Petersburg
КО-РО-ЧЕ. Мне помогла полная чистка вообще всех файлов связанных с автодеском, а иначе он мне даже не давал переставить софт..... Обычно достаточно снести сам макс и почистить реестр.... В принципе отношения с Максом, всегда напряжённые, но бл..ь это уже какой то новый уровень издевательства над пользователем. Посмотрю сколько всё будет работать - позже отпишусь.
Я не то чтобы жалуюсь, но почему такие вещи происходят в момент, когда у тебя несколько срочных проектов и сроки - край в край?) Почему бл..ь не в любое другое время?
Читают эту тему: dianahoshizora77890
